Results 1 to 21 of 21
    Jul 2021
    IL
    Default Tire pressures in hot weather
    I've found that I like the way the RT rides with tire pressures slightly higher than what Can Am recommends. I was keeping 20 in front, 30 in rear. But yesterday which was quite warm, near the end of a 3 hour ride, my TPMS app (FOBO2 Bike) warned me that the rear tire pressure was at 36, which I had previously set as the upper warning level. I was a bit surprised that riding raised the pressure that much, so today I let a bit of air out and lowered the pressures to 19 in front, 29 in rear. This all made me wonder what the upper limit for the stock tires would be.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Air gets more dense, when hot. on a warm day it is perfectly normal, that tire pressure goes up, dunno what the max pressure would be, but I am sure, Blueknight will chime in, else Peter.. they are the tyreguru's on this forum.
    but an increase of 6 is nothing to worrie about
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Northern Kalifornia
    As you've noticed tire pressures can vary greatly given different ambient conditions. If you've read any of the many threads on this site you'll find that opinions come from many directions and for many reasons. And yes the tyreguru's have narrowed down the parameters based on safety and longevity. It's about an even split between those who prefer one pressure over another pressure. Use your FOBO's to adjust your particular pressures to your riding style and likes and stick with them. 36 PSI in the rear OEM tire will rapidly wear down the center of your tire. Ride happy.
    Sep 2017
    Durham,Maine
    For one thing if I was you, having the fobo is a great idea, check the pressure before a ride and make sure you're in your happy zone, but you have to remember that air temp is going to change things a little , and riding it will do the same!! You will drive yourself nuts if you watch it like a hawk, use it as a guide, ride more, worry less, smell the roses!!!
    2012 RTL , Pearl
    For clarification I differ on the PSI 's affecting the wear for KENDA tires in that ..... 90% of tire wear for Kenda Spyder tires has to do with the construction of the tire. Folks here have used various PSI's plus or minus as much as 6 , and the results for tire wear remain pretty consistent no matter what the PSI is ..... The WEAK construction allows the Tire to Balloon at speeds over about 35 mph, and this is the main cause for wear ...... This occurs predominantly for the REAR tire because it's a lot wider than the fronts. .... I have always said " excessive wear for the fronts " is almost always an Alignment issue. Wear when using Kenda tires ( on the fronts only ) is usually pretty decent, but Auto tires will last longer , even the softer compound Auto tires ...... JMHO ...... Mike ..... I'll let Peter chime in of the PSI / Temperature thing ....
    Last edited by BLUEKNIGHT911; 06-19-2022 at 09:17 PM. Reason: Bolding - but do I hafta chime in with all that stuff... again?!? ;-/
    Northern Kalifornia
    My point was that no matter what PSI you run in the Crapenda it's going to prematurely wear down the center tread of that tire. I think it's just about a dead horse now but BRP continues to mount them on their machines. My sinking feeling is, and truly hope not, that some unaware spyder owner is going to suffer a blowout and crash their spyder because they never thought their rear tire would wear down so quickly. Most cars get 50/60k on tires these days and who (unknowingly) wouldn't think a spyder couldn't get the same?
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Piratezz View Post
    "Air gets more dense, when hot." I'm not too sure about that -------- In an enclosed vessel the pressure will certainly go up. Air molecules move faster at higher temps, attempting to push further apart( lower density) but higher pressure.
    I could be wrong of course, ask your local chemist about Boyle's gas laws.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2015
    Vito,
    Pressures like those 30PSI and above on a Crapenda tire will soon have you changing to a proper Auto tire with much lower pressure ( 20psi or so) and much longer tire wear.
    Lew L
    Dec 2015
    Oakley Utah
    To respond to your title question; YES! Temperature can affect tire pressure. The TPMS in my truck always shows at least a 3 psi difference between the side in the shade vs in the sun. Once I start driving down the road and the tires heat up from friction, pressure differential goes away.
    Bottom line is for stock tires on any vehicle ALWAYS go with the manufacturers' recommendations, or pay the price, one way or another. Tire pressures should always be set to specs when COLD, never directly after a trip when they're going to have elevated temperature and therefore pressure.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by Lew L View Post
    Lew L
    I have to agree with you, Lew. Cars and bikes tend to run a bit quicker when it's colder because the air is MORE dense.
    And a baseball that is hit when it's in the 90s will travel just a bit further than when it's hit in the 40s. Why ??
    Because it is less dense.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    This is what Peter advised me when I asked the pressure question. Hope it helps.
    The majic number it seems is 4 psi gain after its all warmed up from cold
    Here is Peters short version.
    "16 - 18 psi up front to start with, but please bear in mind that with radial tires, harder/more direct steering DOES NOT necessarily mean you are getting better traction &/or control, so to erroneously chase that firmer/more direct 'feel' to the detriment of handling, ride, and wear et al from your tires is really not such a great idea!
    Many people have become used to that 'firmer ride' thing thru driving on over-inflated &/or lower profile tires, but the reality is that radial tires in particular NEED to flex somewhat in order to keep the contact patch firmly on the ground and work their best for you, altho going too low is also a risk! So start with your cold start tire pressures at 18 psi & look for a 4psi increase after an hour's riding - LESS than a 4psi increase means your cold start pressure was too HIGH, drop a psi out before your next ride; while MORE than a 4psi increase means your cold start pressure was too LOW, so add a psi before your next ride. Altho the vast majority of Spyders & the tires they can wear will easily fall within that 16-18 psi range, spending a little bit of time now in getting close to the ideal pressure for YOU & YOUR riding, load, surfaces, etc will pay you back in better ride, handling, traction, puncture resistance, tire life et al throughout the tire's life..... "
    2dogs I got your point .... and about the PSI's ..... I only wanted to point to..... WHY THEY WEAR so quickly .... it's all about the construction....I've seen video's a small bridges made of CARDBOARD that allowed a car to drive over it ..... also similar bridges made of wood that couldn't ... It's all in the actual construction ...... JMHO .... Mike
    Bottom line is for stock tires on any vehicle ALWAYS go with the manufacturers' recommendations, or pay the price, one way or another. Tire pressures should always be set to specs when COLD, never directly after a trip when they're going to have elevated pressure.
    Just to add some clarification ....Peter and I always State COLD Tire pressures, we have already added in the normal Temp change that usually occur from riding ..... Mike
    Northern Kalifornia
    LOL, I think we're all on the same page, but not all at the same time.
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Don't forget that the catalytic converter and muffler is in front of that rear wheel.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Quote Originally Posted by SkipH View Post
    If this makes a difference ..... I don't think they or you have instruments that can measure that small of a Temp difference ..... JMHO ... Mike
    Dec 2018
    Elanora, Qld, Australia
    My basic Kends perform a little differently to your advice, Blueknight. Fronts at 17 PSI cold give me 30+K km. Rear at 22 PSI cold gives me 20+K km. Not arguing with you, just stating my facts with about 70K+ experience, the last 50K km mostly in the hills, with vigour. Present ryde is 2020 F3Ltd.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Sep 2017
    INDIANA, USA
    Default Tire Pressure TIPS
    ....I have been doing the 4 mile check for a long time. I have been doing this for years. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Quote Originally Posted by RazzleH View Post
    Thank you for commenting .... Anything I say about Kenda tires is gleaned from what others here have said ( except for their construction ) since 2009, I have always switched to Auto tires ASAP .... Kenda has changed their tire compound formula a few times during that period .... I have read that a few folks ( very few ) have gotten mileages as high ( and more ) than auto tires. .... These folks seem to be in area's where the road surfaces are unique ... in that tires wear LESS quickly than most roads .... Although I know a lot about tires, I have NO answer as to why this is possible ..... over to you Peter ......Mike ..
    Active Member rv6a's Avatar
    Mar 2021
    Indiana
    You are correct, air gets less dense with temperature and altitude.
    Lew L
