Oil, Filters, and O-Rings for 1330 engine
All brand new, never used or opened.
5 quarts of oil
3 oil filters
2 o-ring kits
Sells new for $90+
All is yours for $55 including UPS shipping (has to ship UPS due to oil).
Note: It is all or none - I am not selling piecemeal. Also, the oil is leftover from previous oil changes on a couple of different bikes - not just Can Am. I think the 5W-40 is what the 1330 engine calls for in the Can Am manual - the 10W-40 will work fine as well for most areas and may even be preferred if you live in a hot climate. Most modern bikes with wet clutches use the same oil so the only difference is viscosity specified by manufacturer - but I am not going to get into a discussion about oils here!
PM me if interested.
Will
Sold: 2020RT base with numerous improvements and farkles
Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
Sweetening the deal here: I will throw in a 2020 RT Service Manual on disc, $25 value. IIRC, this is basically a PDF file which you can copy and store on your computer's hard drive if you like.
Info on disc should cover '21 and '22 RTs as well.
PM if interested.
Will
