Results 1 to 3 of 3
    May 2021
    NC
    Default Is there a Honda Part # for a Y gasket to fit 2015 ST-S?
    Does anyone know if Honda makes a Y gasket that will fit on a 2015 ST-S. The one everyone talks about for earlier models won't work (different Can am part numbers).
    Nick Capano
    2015 ST-S
    Nov 2015
    Chardon, OH
    Nick. Wow. You did a deep dive on that Search. You are correct. The Honda Y Gasket was only for the earlier 998 engines. You use the OEM part, not a Honda part. The earlier OEM gasket had a dismal failure history which is what started the whole Honda part replacement in the first place. The exhaust header joints are different now, and the OEM gaskets for your engine don't have that problem. When properly installed and the clamps kept tightened, the OEM gaskets for your engine will last just fine.
    Doug
    ”Freedom is not a loophole”
    May 2021
    NC
    thanks Doug
    Nick Capano
    2015 ST-S
