Results 1 to 11 of 11
    May 2016
    Shoreline, WA
    Default Anyone replaced OEM RT-622 trailer tires? What with??
    Hello, I have a 2012 RT-622 trailer with the original Load Star 4.80x12 tubeless tires. Since they are 10 years old (with not many miles 5K maybe) I'm thinking new ones are in order. Anyone replaced these? With what?
    Thanks All
    Sep 2014
    USA
    Oh Boy. Hope this does not turn into a mess.
    But these are a Kenda Tire. You could just get the same tire.
    Or another 4.80 x12 tire will work.
    Good Luck
    That's an OLD tire ..... even if the trailer was kept out of the sun .... it's on borrowed time ...Even if you have it fully loaded that's only 400lbs. and will put less stress on each tire ...... So if you have fobo psi detectors on the wheels , when it goes flat you will know immed. and can change it ..... good luck .... Mike
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by Uticat View Post
    Thanks All
    I'd PM Ann Meyer, she has replaced many of them.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    indpls in
    northern tool $95 or check out e trailer
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    I asked this question a few years ago and replaced with the Kenda Load Stars with the recommendation of Ann.https://www.spyderlovers.com/forums/...res-for-RT-622
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Quote Originally Posted by YIRYDE View Post
    JMHO < but I suggest buying the least expensive tire that will fit ..... UNLESS you are using the trailer a lot ..... most of these trailer tires for lightweight trailers will ROT from age long before they wear out ..... good luck .... Mike
    Dec 2020
    Hartwell, Ga
    indpls in
    be sure to repack wheel bearings while your at it
    May 2016
    Shoreline, WA
    Thanks for the Pep Boys heads-up, $30 ea. Looks like a good tire
    Dec 2020
    Hartwell, Ga
    When I replace mine I'll be going with these also.
