Results 1 to 18 of 18
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Default What size Oetiker Clamp is needed on lower Radiator hoses?
    Anyone happen to know what the size is for the Oetiker clamps on the lower radiator hoses? These things are $8.50/ea on the parts sites, yet $20/hundred in bulk. Not looking for worm clamps.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Feb 2020
    N. Wilkesboro, NC
    I don't know what size you need but Lowe's seems to carry them, too. Lowe's lists them as Sharkbite PEX clamps but they seem to be the same. Looks like 5 bucks for 10 or 10 bucks for 25.
    2021 Honda HRV
    2245 Constitution class starship (refitted 2270-2271) (for sale)
    2021 Can Am Spyder RT (gone)
    2019 Honda CR-V (gone)
    2018 Can Am Spyder RT Limited (gone)
    2014 Kawasaki Nomad (gone)
    Mar 2008
    Hesston, PA
    Quote Originally Posted by Jetfixer View Post
    If I remember correctly when I needed the lower Oetiker clamp when I changed the coolant on my 2014 RTS 1330 a few years ago...I tried to cross reference the size to the Oetiker clamp catalog and HAD NO LUCK finding the exact size needed...I think the BRP size is a exclusive for BRP ONLY...JUST LIKE THE GOODYEAR AIR BAG/SPRING...I THINK I have a spare or two out in the garage and if you have a BRP part number I will measure one for you...larryd
    Jan 2019
    Western PA
    I’m not sure about the 2020 model yr, but for previous years I have used a 36.1 Oetiker clamp.
    2022 RT-L , Silver
    Jul 2014
    Mint Hill, NC
    The 36.1 mm Oetiker clamp is what the parts fiche for MY '14 - 20 calls for , but I assume that's why you asked, JF.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jan 2021
    Descanso, CA
    Lightbulb Use constant torque clamps
    You're correct worm gear clamps will not seal properly and can damage the radiator hose. Use constant torque clamps instead. https://www.amazon.com/dp/B00N9AEH0M
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Mar 2008
    Hesston, PA
    I checked my garage inventory of Oetiker clamps today and this is what I found;
    36.1 Oetiker BRP #509000045 1.421
    38.1 Oetiker BRP #293650199 1.500
    Oetiker stepless screw clamp 39.9 #233060138 & 40.9 #233070117 Here is the link to these; https://www.oetiker.com/en-us/produc...w-clamp-pg-178
    I really like their stepless screw clamps for 1 1/4" and larger hoses...
    PS. I have a bag of 25 of the 38.1 size...If anyone wants several, you pay the postage and I'll send you several...larryd
    Feb 2016
    Thank you all for the replies. It turns out it still is the 36.1 on the 2020.
    Sep 2014
    USA
    Mar 2019
    NEBRASKA
    I used the worm type on the RT fuel filter but I have a question about Oetiker.....do we use these Oetiker because they have a preset amount of pressure applied circumferentially? And do we use a special tool to apply these?
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Feb 2016
    Quote Originally Posted by davev1pa View Post
    Yes, and Yes. Worm clamps do not apply pressure equally, and most people way over torque them. That's why you see the rubber squirting out through the worm slots. It's a condition called, "cold flow", and is damaging to the rubber. There is a special Oetiker pliers that is used to set the clamp properly. Most importantly, it's the sizing of the clamp that is critical. The open size of the clamp is for the hose or tube diameter, and the closed size is for the exact clamping pressure that is required. Oetiker clamps are not reusable.
    Mar 2008
    Hesston, PA
    They make hose clamps with a metal lining that will prevent the "cold flow" problem...These lining clamps are a MUST USE on silicone hoses and they work equally well on all types of hoses...
    Here is a picture of a "lining hose clamp" https://www.pegasusautoracing.com/pr...p?Product=3613
    May 2018
    Chateauguay, Qc, Canada
    There may be a width problem as these are 1/2"(12.7mm) wide.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by larryd View Post
    IMHO, these work just as good, are less expensive and are easier to remove/install as those Oetiker clamps.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Mar 2008
    Hesston, PA
    Quote Originally Posted by Eckhard View Post
    Then look at these; Oetiker stepless screw Here is the link to these; https://www.oetiker.com/en-us/produc...w-clamp-pg-178
    Feb 2023
    WI
    Hello, will the 38.1 size work on the radiator hose for the 2017 spyder rts?
    Thank you
    Al
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Recently I used this clamp, to replace the Oetiker clamp, on the R/H lower radiator hose, when changing coolant on my 2018 F3L. It was worked well aka, no leaks. Purchased through ebay: narrow Band 9mm Steel Hose Clamp 25-40mm - Made in Germany Pack of 2 HC25-40/9
    Feb 2023
    WI
    What size stepless screw clamp will I need for my RT lower coolant hose? Thank you
