Results 1 to 5 of 5
    Jun 2017
    Rapid City, SD
    Default Knocking sound on deceleration was loose front pulley!
    I had a sound on deceleration that almost sounded like an engine knock. Took it to my mechanic and traced it down to the front pulley. It was still in good shape, but it turns out that the bolt was slightly loose. After locktight and re-torquing the issue was resolved. Still going to have the recall stuff done though. Think it covers both the bolt and the pulley if I read right.
    HE>I
    2017 RT , Asphalt Grey
    Aug 2008
    MA & NH
    Glad you got it resolved.
    Jun 2017
    Rapid City, SD
    Just thought I’d share in case it happens to someone else. Mechanic said it was a first for him too.
    HE>I
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    The bolt not tight enough, might just be the "red dust"starter, imho, if the pulley/sprocket is slightly loose, it could move on the splines, causing the rust, and the rattling noise...
    again just my two cents
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Piratezz View Post
    Yeah that was my mechanic’s theory too…. Makes sense.
    HE>I
