Results 1 to 20 of 20
    Jun 2020
    San Antonio, TX
    Default Spyder engine will not turn over?! What did I miss?
    Just got stranded...2013 RTL had been running fine and driven most days. I stopped at a local place and came back out to find it wouldn't start. In fact, i do not get the warning screen where i need to press the button to start. Battery is near new. It is in neutral. I removed key for a spell and tried again with no luck. I unhooked the battery in hopes the computer would reset. The warning screen flashed for a second and disappeared. Still won't turn over. All lights and everything else works. What did i miss?
    Quote Originally Posted by Chiefburg View Post
    Even NEW - RECENT batteries can be defective ..... I don't think the computer can tell you " the batt. is bad " ..... If you can't test it yourself .... most auto parts stores will - for Free ..... This should be step #1. in this p[rocess ..... good luck .... Mike
    Jun 2020
    San Antonio, TX
    True, the battery could be bad. Couldn't even get it to turnover with a jump. I'm not getting the screen i need to press the mode button to start.
    Nov 2015
    Chardon, OH
    Hey Chief. How long was it turned off? By design, that warning screen is skipped if was only for a few minutes, and it goes straight to the main driving screen. You didn’t mention checking the kill switch. If it’s not in run, the motor doesn’t turn over.
    Doug
    ”Freedom is not a loophole”
    with Snowbellt ... if the KILL switch is OFF ...jumping won't work .... PS do not have the motor running in the veh used ..... Mike
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    A cheap voltmeter is a good bit of kit and is very useful with these type of problems.
    Aug 2007
    Greeneville, TN
    Spyder will not turnover
    You just need to try harder!
    Jun 2020
    San Antonio, TX
    Quote Originally Posted by Snowbelt Spyder View Post
    Kill switch? Who knew????
    Owned this several years and never touched the kill switch... Didn't even cross my mind. Yes, it was the kill switch... Must have hit it somehow. I guess I have learned my lesson...
    Feb 2022
    New Zealand
    Nov 2015
    Chardon, OH
    Or…you got pranked in the parking lot by somebody who knew something about bikes. Yet another reason to make using the kill switch a habit. Glad it all worked out. Be safe out there.
    Doug
    Dec 2013
    You aren't the first to get caught by that.... . Nor will you be the last!
    At least it was a relatively easy fix . and a lesson learned that few of us who've experienced it will ever forget easily!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2022
    New Zealand
    Pleased ya got it sorted.
    Cant understand the use of the kill switch in normal riding situations, cept like the last time I used it. It was on my DR 650. It was lying on its side screaming its guts out. I crawled over and shut it down.
    Usual riding. No way. I use the key.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    This was a common prank "buddies" would play on each other at work.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    May 2017
    Mesa, Arid-Zone-A
    Doesn't that make you a little embarrassed.....? I know I was when it happened to me...... Jim
    Semper Fi
    Mar 2015
    forrest above Reno, Nv
    Default Reversed their prank-----
    The kill switch prank was pulled on me on a ride with too many strangers. I gassed up and went inside to pay. The wouldn't start up as usual. I turned around and looked at the " group" , flicked the Kill switch back on and laughed at them.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2007
    Greeneville, TN
    Some will admit it. And some won't. But we've all gotten caught on this one.
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    would never happen to me. I guess I am one of the few that uses it every time I shut the Spyder down. Glad is was something simple and free (that don't happen often)
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by canamjhb View Post
    2020 RT Limited , Petrol Blue
    Jun 2015
    Ritzville, Wa
    As an official member of the Kill Switch Club, your in good company. I joined on my 2nd day of ownership.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    I had already called a tow truck (after 1 hour of trying to figure it out!! Lucky the guy didn't even charge me; since he was close to his next call. Boy was my face red. I actually fixed it by mistake when trying to take apart the control switch!!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
