Results 1 to 7 of 7
    May 2020
    Australia
    Default Is this Belt Noise from Left side of engine normal? Goes away when warmed up?
    Belt type noise coming from my engine left side, goes away when it heats up. Never noticed it before, is this normal? John.
    Last edited by Peter Aawen; 06-07-2022 at 04:20 AM. Reason: Revised title to briefly ask question... ;-)
    Quote Originally Posted by Patt View Post
    There are some here who have exceptional hearing ( you might be one ) and have noticed some " whine " from the previous re-design of the front pulley .... The last re-design the " white ones " were supposed to cancel that whine .... Now it has been reported that another NEW design is coming to Correct the " pulley failure rate for pulley's made after 2014 ..... good luck .... Mike
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I have the whine at 70 Km/h, goes away at 71 km/h, under 70 no whining. Cannot wait for the new white pulley/sprocket
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    May 2020
    Australia
    Thank you for the reply. I am talking about when the bike is first started, not on the move. It comes from the engine when cold.
    Nov 2018
    Lisbon, Portugal
    Quote Originally Posted by Piratezz View Post
    Have that also and on my second pulley (a white one).
    I would suspect it's rather related to somekind of harmonic vibration of the belt.
    Maybe lowering the tension might help I've got mine set to the recommended 180lbs/ft.
    2018 F3S , Monolith Black Satin
    Nov 2018
    Lisbon, Portugal
    Totally normal. Mine does it and I think all are doing it, still more noticeable on some then others.
    It has been described as marbles jumping around inside and I believe it may have to do with the engine having a dry sump.
    Quote Originally Posted by MakoShark2 View Post
    160 measured with wheel on ground worked for me ..... JMHO .... good luck .... Mike
