Results 1 to 5 of 5
    Nov 2015
    Eau Claire, WI
    Default 2017 RT Limited GPS Re-Location to above dash - who makes the mount?
    Greetings,
    I just acquired a 2017 RT Limited with the Zumo 590. It is mounted by ignition key. I'd like to move it so that the GPS would more in my line of sight above the instrument cluster. I've seen this done. However, I can't remember the name of the company who makes this possible. There is a black metal bar that is fastened by the two screws in the instrument cluster cover. What is the name of that company? Any other hurdles that could pop-up? I can see the GPS cable routing as one problem. Thank you in advance for any help or advice.
    Last edited by Peter Aawen; 06-15-2022 at 06:56 PM. Reason: Removed Prefix - not engine/size related & briefly stated question in title ;-)
    Mar 2017
    Salisbury,NC
    JT (something) I bought that water jet bracket. Then I made a block to extend farther out to hold cradle that was on handlebars. Sorry don't remember last part of name.
    There is older posts on this , somewhere 2018 timeframe
    https://spyderstore.com/index.php?route=common/home
    Found it!!!!!!!!!!
    Clinton, MS
    Quote Originally Posted by rickmoen View Post
    Greetings,
    https://www.spyderlovers.com/forums/...ighlight=mount
    Look at post #3
    Nov 2015
    Eau Claire, WI
    Great! Thank you so much.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Yeah, I've got that on mine, the antenna for the XM was on it. Now it's empty as I haven't found anything to put on it.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
