Results 1 to 25 of 41
    Jul 2017
    Woodbine, Iowa
    Default Anyone had their Rear shock leak oil??
    Has anyone had their rear shock leak oil? I had the bolt come out on the bottom of the shock and now my shock is leaking oil!
    Last edited by Peter Aawen; 06-04-2022 at 07:07 AM. Reason: Revised to briefly state the question in the title. ;-)
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Durham,Maine
    You probably have a blown seal! Have you got a lot of oil coming out or is the shaft just got a light film on it?
    2012 RTL , Pearl
    Jul 2017
    Woodbine, Iowa
    It is leaking pretty bad. I will have to find a dealer it is under warranty. I am concerned they won't be able to get parts right away. Is it a big job to remove the rear shock?[
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Durham,Maine
    Getting to the bolts are the hardest part, getting the shock, I would not think that would be a big deal! Good luck! The stock shocks in these thinks are not that good in my book, be glad you're under warranty.
    2012 RTL , Pearl
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    it's a bit off fiddeling with the inside fender, on a f3, but not a 5star job
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Sep 2014
    USA
    What do you mean the bolt came out of the shock??
    Jul 2017
    Woodbine, Iowa
    At the factory they must not have tighten the nut on the lower bolt of the rear shock. The bolt had worked out and the shock was just caught by the tip of the bolt. The shock was twisted in the holder. I jacked the Spyder up and was able to get the bolt back through the shock and had a flat washer, lock washer and nut to tighten it back in place. Everything looked fine except oil leaking from the shock. Now I can just bounce the rear of the Spyder to the bottom with one hand and it sets real low to the ground. The shock has very little oil in it. It is a 2021. I have had it about two months and have 1900 miles on it, so it is in warranty. If it wasn't in warranty, I would purchase a Elka rear shock and replace it myself. I am to take it into a dealer Tuesday (May7th) and they will look at it. What I am afraid of is they will not get parts for a month or so. Things I have heard. If is just a shock and they can't get it I will have them order a Elka shock and I will pay for it.
    Has anyone on here replace their rear shock with an Elka, they are about 900.00 dollars? Is there anyone else that makes shocks for Spyder's?
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Harrington, Australia
    Quote Originally Posted by Piratezz View Post
    Yeah, but it’s a bit of a pain on the new RT, Piratezz. You have to take off the Tupperware both sides, then the internal black panels and floorboards both sides, to remove the shock. It is a tight area. It is not a particularly difficult job, but it takes time and the right tools……
    Gerald, I would be concerned about associated damage to the frame mounting plates if only the edge of the bolt is holding the shock in. I personally would be getting the dealer to fix this under warranty. You could do what I did and buy a 3rd party shock if the dealer doesn’t have stock.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2014
    USA
    I have a M2 shock that has been working very well so far.
    In fact the compressor is still hooked up but system has no air in it and compressor never cycles anymore. So the shock is doing its job..
    First I ever heard of the rear shock bolt backing out.
    Jul 2017
    Woodbine, Iowa
    The Bolt never broke off. The nut came off and the bolt worked its way out.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Quote Originally Posted by gerald37 View Post
    Without thinking too hard about it, there are quite a few threads on Elka's here on the Forum, some extolling their virtues, others not so much! . There's also quite a few threads on M2 shocks, generally people are happy with them; and more recently, there's a growing number of people who've found (or possibly been pointed towards... ) IKON shocks. So there's a few different shocks to look at & make yuour choice from if you need to go aftermarket; but I'm with the other's here suggesting that you should take this in for a warranty replacement, and only go aftermarket if/when they can't/won't replace it in a timely manner!
    Faribault, MN
    +1 for the M2 Shocks, Replaced my factory shock on my '13 and never needed the airbag after, though kept it inflated to about 40lbs.. Marcus custom tuned our M2 shocks to my (excessive) weight plus my diminutive spouse. He sells rear shocks alone or get a whole set and get a much better ride.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    I suppose if they haven’t tightened the lower nut (or have forgotten to put it on at all ), the constant up and down movement could allow the bolt to gradually work its way loose each time it hits the “ no resistance” point , Triker.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2014
    USA
    Yes I am sure if the nuts fell off or was never installed it would come out or do some damage to the shock and mount.
    This is the first I have ever heard of this happening on a spyder.
    Jul 2017
    Woodbine, Iowa
    Yes the bolt did work out. I have had it on ramps and rear jacked up so I could get under it and got the bolt in with washes and nut. The lower mount looks okay. Everything looks good except the shock leak all the oil out. I don't think it did any other damage. I have a friend that is hauling it to a dealership in the morning. I think I could ride it but it is pretty soft just the air and spring on the shock is carrying it.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    I took the Spyder to the dealer and they called me the next day. They said they thought the only thing it needed is a rear shock. When they install it they would check everything. They ordered it, now I hope it don't take a long time getting it.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Good to hear, Gerald ….except for the possible wait time on a replacement.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2017
    Woodbine, Iowa
    If they can't get the shock right away I will pay for after market shock.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    I picked up my Spyder yesterday. They said all they had to do was replace the rear shock. I rode it home and noticed it rode really rough. I thought they might have a little to much air in the air bag. Got home and check it and it had 90 lbs of air in it. I let it down to 15 lbs. and rode it. It rode great for about 3 or 4 blocks and back rough again. Took it home and checked it and it had 70 lbs of air in it. I tried again did the same thing. I call the dealer and they told me it could be several things. They said they would come and pick it up and take it back at no charge. I am getting disgusted with it. This is my third Spyder and I had no problems with my first two . I have read on the internet of how many problems other people have had. I don't think I would buy another one.
    Last edited by Peter Aawen; 06-23-2022 at 07:54 PM. Reason: discussed - disgusted ;-)
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    May 2020
    Spyders are complex machines. If they run, they work good, but everything with wheels will break at one point. You are just the Lucky guy who has it happen all at once....
    So when all these glitches are solved, you are going to have a wonderful machine, don't step outta the game for a few glitches! You know you wanna ride the thing.....
    Swaybar (Ron's)
    Durham,Maine
    Once they get your air system dialed in you will be a happy man, until the compressor craps the bed! That whole auto ride system is a pain - when it works, it's nice, when it doesn't... well, I don't have to tell you what that is, you're already there!! Good luck anyway, at least you seem to have a good dealer that wants to work with you and make it right!!
    2012 RTL , Pearl
    Jul 2017
    Woodbine, Iowa
    Yes the dealer is trying. Especially I didn't purchase the bike from them. I think they will get it worked out. I just hope they don't have to order parts again.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Sep 2014
    USA
    Didn't they test it, since all you did was drive it home and you had a issue already. Its not the Spyder its the people working on it.
    Gerald, my airbag does get up to 90psi when I am riding (but I am 300lbs). It then drops downs to 70 once I get off (I have a FOBO unit connected). It adjusts automatically to the rider, so I’m not sure what you expected to achieve by letting it out to 15psi, as it would automatically re adjust when you turned on the RT and sat on it. I’m not sure the issue is with your airbag.
    Can you confirm that they reconnected your small seat to frame arm on the left side of the RT? You should be able to see it if you get on the ground behind the RT and shine a light alongside the rear seat. It’s about the size of your forefinger and connects the seat to the frame.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2017
    Woodbine, Iowa
    No, I don't think anyone rode it. Like I said, I noticed it riding a little rough, but I thought they probably put too much air in the air bag.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
