New BakerBuilt AirWings for F3’s
How do they mount to the F3?
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Don't know about the F3 but I have them on my RT. I have both upper and lowers and they make cool morning rides much more enjoyable. Also, open them up and they make the hot afternoons much more tolerable. The only issue I found is fitment. Because I'm a DIYer it was not a problem for me. But, if you expect every little item to fit exactly as it should and you don't like adjusting anything, then they may not be to your liking. By the way, it's not Baker's brackets that are the issue, it's the two different sides of the spyder that comes into play.
They mount to the underside of the mirror housing. There is also a hole drilled to the top of the housing for a tiny screw to help hold it on as the Airwings could pull the housing off. The one image shows the capped screw on top. The other shows how the wing is attached.
5132C3FC-888C-4EA2-A3D7-BF3CB6454812.jpg 9F39D9FD-3B16-4717-9711-7EF52A85CEE2.jpg
Does this not cause your mirrors to shake and become useless?
The newer models have the updated mirror mounts and I just did close to 80mph and no problems. Earlier models would need the mirror update kit or the kit LaMonster sells.
I just got a set from Slingmods, and the brackets were not for a "T".
Thanks for these pictures! Now to find out what went wrong in my order process..
Please don't spook the road-sheep.
I think you want these. http://bakerbuiltairwings.com/prodde...p?prod=SPYF3HW
I called Slingmods, and they are looking into it.
The picture in your link are the older mirrors. My 2020 is not like that..
i have them they work great
Oh boy - yet another mod I may need to add to my "to do" list...
2021 F3 L , Stock Plugs (COILS, NOT WIRES!) Stock Brake Pedal Magma Red
Baker has Airwings for both old and new mirrors. Check their web site.
Originally Posted by Flamewinger
Actually for the F3T and F3L you need this part number
http://bakerbuiltairwings.com/prodde...?prod=SPYF3THW
"Stupid is as Stupid does"
Don't Drink and Drive or Ryde!
Each Day is a Gift
Slingmods had me send them back direct to Baker for exchange. They didn't have that type in stock. I suspect they will now.
