Page 13 of 17 FirstFirst ... 391011121314151617 LastLast
Results 301 to 325 of 418
  1. #301
    SoFlo
    James Thorne, next time you pull a sprocket / pulley, can you check if Rotax used a wear collar between the pulley and the output shaft bearing inner race.
    Typically, manufacturers do not have the gearbox output shaft seal ride directly on the gearbox shaft. Most times a collar is slid over the shaft, sometimes using a small o ring to prevent leaks, that allows the seal to wear into the easily replaced collar.
    If there is a collar, one would expect it to be made longer rather than install a washer.
    Regardless, the pulley bolt merely keeps it from falling off the shaft. The splines provide the torque interface for motion.
  2. #302
    Sep 2013
    Houston
    When you pull the sprocket, you can see the face of the shaft seal. Its rubber faced. From the parts breakdown, the bearing is right behind that seal. The sprocket rides against the shoulder on the shaft, it does not touch the seal. Adding a collar will space the sprocket outward by the thickness of the collar. You are correct that the bolt, sprocket, shaft clamping has little to do with torque transfer or to keep the sprocket from moving on the shaft. That is the splines and the new collar will not change the play between the splines and therefore the fretting issue.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  3. #303
    Jul 2020
    Isanti, MN
    Im in Minnesota and my local dealers still dont have the parts and said the interim fix was actually just an inspection.
  4. #304
    Jul 2020
    Isanti, MN
    Why do that? They get paid for the work dont they?
  5. #305
    Oct 2013
    Farmington, Delaware
    Below is the link for the TSB for the inspection and interim fix.
    https://static.nhtsa.gov/odi/tsbs/20...14930-0001.pdf
    SpyDel
    2017 F3 Limited
  6. #306
    Mar 2015
    forrest above Reno, Nv
    A friend in our Battle Born Spyder group just had her F3 in the shop AGAIN for the sprocket fix.( first sprocket failed about 2 yrs ago) Now waiting for parts. BRP and CanAm needs to stop making the sprockets out of cheese AND solve this problem quickly as their reputation for quality and reliability may spread to their other products.
    2014 RTS , Circuit Yellow
  7. #307
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Lew L View Post
    Being from Wisconsin, I resent your cheese remark
    2022 RT Sea To Sky
  8. #308
    Nov 2013
    Central Texas
    I did not realize that BRP had a reputation for quality and reliability, or integrity for that matter. They really do not have a reputation for solving problems quickly.
  9. #309
    Idaho
    cheese
    Wrong color! Should be cheese! ! ! ! !
    2014 Copper RTS
  10. #310
    Mar 2015
    One of my favorite cheeses is blue
    AND:
    In response to Fritz above about reliability, quality, and integrity--------
    Just look up D.E.S.S, front sprockets, Kenda tires, switch gear, drain plugs, belt vibration, and I could go on and on. I haven't had all those problems with my but if we took all the forum members who did have reliability, quality, and integrity problems it would be a LARGE percentage.
    Not attacking you Fritz........ just stating the obvious.
  11. #311
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    anyone know why the 2014 1330s werent included in this? because they could get away with it? replaced mine last year on my 14 RT SE6 LTD with about 30k its the only thing my extended warranty has covered but ive only got about 35k on mine.
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
  12. #312
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    Put a complaint into your national vehicle safety authority and attach recall notice.
    The best substitute for brains & knowledge is....................silence.
  13. #313
    Idaho
    Quote Originally Posted by AbNormy View Post
    Here are my thoughts about why that is the case. https://www.spyderlovers.com/forums/...=1#post1646273
    Also this one in the same thread. https://www.spyderlovers.com/forums/...=1#post1647288
    2014 Copper RTS
  14. #314
    I'm not so sure about this ...... I've read 99% of the threads / posts about this and I recall someone posting that the last Month of 2014 production had a couple of Red Dust issues ..... and these would be covered by the re-call ..... JMHO .... Mike
  15. #315
    Jun 2019
    Deltona FL
    If they'd only put the quality & craftsmanship into the Spyders as they do their snowmobiles, we'd be all set!!
  16. #316
    Feb 2017
    I stopped by my local dealer Saturday (happened to be the annual "Block Party at Kent Powersports, San Antonio, TX) and had a chance to talk with the service manager about the front sprocket safety recall. Here's what I learned. My 2015 RT-S will be inspected tomorrow (about 30 minutes). If there is visible excessive wear/damage a new sprocket will be installed as a stop gap while awaiting replacement parts from BRP. According to the manager that can be expected in January some time. Not a very good response by BRP to a federal government recall, but at least this dealership appears to be taking a proactive approach to the problem.
    Has anyone else heard anything different? It would be interesting to know.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
  17. #317
    Sep 2017
    INDIANA, USA
    ... I talked with my Spyder Dealer and learned that they are waiting for some parts to come. No real answers yet about when they will get the parts. Still waiting...
    ENJOY YOUR LIFE WITH A SPYDER
  18. #318
    Jun 2011
    Alamogordo, NM
    The question is, are the current white sprockets available or they back ordered also, pending the final elusive fix???????
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
  19. #319
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by old Timer View Post
    I ordered one in July or August (after the announcement of the recall) and received it. Can't say they are available "today' but they have been available post recall announcement for sure.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
  20. #320
    Nov 2016
    Colorado Springs
    I got my spyder (2019 Rt Ltd) from the shop with the warranty repair. It snowed last night so no riding today, but It drove off the trailer last night and up into my garage.
    Freemont Motorsports in Florence Co.
    Dropped off August 13, 2022
    Picked up November 10, 2022
    My sprocket was a complete failure. Lost all power to the rear wheel as I pulled onto the highway during a multi day ride. Engine Revved, loud noise but no power. I have a stinger trailer so I was able to tow it home from Durango to the shop.
    Here's the sprocket. Very small ridges left on the inside. The mechanic was supposed to get pictures of the shaft but forgot. They said it looked fine with no serious wear.
    Here's a video of what it sounded like. The bike is in gear, brake is off. Revving gives no power.
    Side note - Mechanic received the part last week but when they went to install it, the box actually contained a water pump. So I actually got the part destined for the next guy (Sorry about that) which arrived a few days later. I guess BRP still doesn't have their act in gear.
  21. #321
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Quote Originally Posted by Arion View Post
    That is exactly what my dealer (RideNow in Peoria AZ) did to mine back in June. Saved my riding season for me.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
  22. #322
    Oct 2021
    Wichita, KS
    Quote Originally Posted by ClayJ View Post
    I'm not trying to be too negative here but I cannot imagine there is no damage to the output shaft with that pulley in that condition. Especially after revving it a few times like you did in that video. Hopefully you have a good mechanic who is being completely honest with you.
    Peter Pan has struck again!
  23. #323
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by FrogmanDave View Post
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
  24. #324
    Nov 2016
    Colorado Springs
    That's the whole problem with mechanics. You have to trust that what they are telling you is the truth because "Insurance won't allow customers into the shop to see for themselves". But in this case, I don't think they have any incentive to lie about it. If the shaft was damaged, they said it would be repaired under the recall. Still, it broke after only 2 years and 16K miles, so the sprocket was really soft to wear down that quick.
    Has anyone produced a video about how to do your own check on the sprocket? I guess it's not too bad to pull a bit of tupperware and it's just right there.
  25. #325
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    I've been busy and haven't been on SpyderLovers in awhile, so I was hoping to get on today and find good news on this topic. Why? because at approx 50K miles, my first sprocket failed, and then at approx 68K miles the second sprocket also failed and my spyder has been in the shop since mid October waiting for parts. I spoke to them earlier this week and they said that they had received the parts for the "final fix" on the recall and that it should be ready for me this week. Based on that conversation I scheduled my husband's recall fix for later this month. They called me yesterday to say mine was done so I rode it home (brrrrr!). I also asked my "regular" service contact about whether this was the "final fix" and he confirmed that's what he'd heard as well. He also said that the fix was to replace the sprocket. I replied that "this is my third... not sure I really trust that". Not much he could say in response other than agree. I guess time will tell. I was hoping to get on today and have a lot of others saying how they'd also gotten their recall issue resolved. I guess not
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
Tags for this Thread
