Page 6 of 17 FirstFirst ... 234567891016 ... LastLast
Results 126 to 150 of 418
  1. #126
    Mar 2019
    NEBRASKA
    Curious if any 2014's would be at risk...my 2014 RTS has some red dust but seems to be in overall good shape...Is there any structural differences? Did BRP use a different sprocket after 2014?
    2012 RTL 14 RTS , Pearl White @ Pearl White
  2. #127
    Quote Originally Posted by davev1pa View Post
    I've only heard of a couple of 2014's that show RED Dust .... so far mine isn't one of them .... I think it was JC Thorne who posted that 2014's made after April have shown some Red Dust .... Then in 15 the F-3 showed it first ..... good luck .... Mike
  3. #128
    Mar 2019
    lakewood ranch fl
    Thank you Mike
    2019 F3 limited
  4. #129
    Oct 2015
    Lynden, WA
    Talked with my local dealer yesterday. They are NOT doing interim repairs for the red dust.
    Any repair is at the owners cost.
    The dealer said BRP will not have a solution until Aug 22.
    Its going to be a long wait...
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  5. #130
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Haze View Post
    Sometimes I really wonder about BRP. I know there are supply problems BUT they have known about this for a long time. Our local dealer charged a member of BattleBorn Spyders a lot of money to change out a front sprocket on her F3( and it was a long tow from Lake Tahoe to Reno)
    It took a few Spyders catching fire to get BRP to fix the overheating problems with the 2013 RT's and they NEVER did much about the DESS problems in the 2014's
    See you and Lou on Friday
    Lew L
    2014 RTS , Circuit Yellow
  6. #131
    Aug 2020
    Il
    Quote Originally Posted by Lew L View Post
    Lew L
    Love the edit and the typo.
    21 Spyder base F3
  7. #132
    Sep 2015
    Chilliwack, BC. Canada
    Well, after reading all of the posts on this subject, i decided that I’d better not leave my head buried in the sand, and should investigate my 2014 RTS just a bit further, so I dropped by my dealer (the original selling dealer, I might add) and had him look up my unit to see if there were ANY recalls outstanding for my unit. There was NOTHING. I then went a step further and had a look on my swing arm for the plate with the assembly date on it. The plate shows a date of 12/2013 (December 2013). I’m doubly good!
    Last edited by bigbadbrucie; 06-15-2022 at 07:55 PM. Reason: Can’t seem to see straight!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  8. #133
    Oct 2015
    Lynden, WA
    I bought a White Sprocket/Pulley early last year. I have the pulley in storage for use in an emergency.
    The pulley is available (at cost) for any member of BattleBorn Spyders.
    If not needed by Mid July I will carry it with me to the D3WR.
    Cheers, David C.
    Will be there Friday with bells on. I do look good in bells...
    David C
    2016 F3T
    Rear IPS Pack Rack
  9. #134
    May 2019
    Surprise,az
    I have a 2015 rt se6. My sprocket went bad on way to work. They replaced parts and labor about $800. I called dealer and they told me “Maybe” after they investigate. Called Canada. They opened a case and are investigating. In other words DONT HOLD YOUR BREATH!
  10. #135
    Aug 2016
    Cleveland, Ga
    Quote Originally Posted by Jdr00ejr View Post
    Did folks see this???? Seems like this is the Red Dust of Death - finally being recalled! :-). Do others read this the same way?
    https://can-am.brp.com/on-road/us/en...ropulsion.html
    My dealer told me that they have not been told what even the temp. fix is yet. He said to wait til you are notified that the fix if ready and then contact them.
  11. #136
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Quote Originally Posted by t.p. View Post
    here is the brp recall page to check your vin# for the sprocket recall https://can-am.brp.com/on-road/us/en...y-recalls.html
    t.p.
    check your vin# above
    A friend of mine was on the recall vin check, So he called BRP to find out why he didn't get an email about the recall, The BRP
    rep told him that he was not on the recall list. He sent her a copy that he was on the list. OOOPS She said.
    T.P.
  12. #137
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    wife got recall letter today 2018 f3t
    2019 f3t , titanium
  13. #138
    Feb 2022
    NJ
    I got the recall letter today for my 2015 F3-S.
    Said they will be ready to do the temp fix procedure starting June 30. I have not made an appointment yet.
    Also says the permanent fix will be ready at the dealer starting August 30th.
    Before I bring it in I want to know what the temp fix is and what the permanent fix is.
    Hopefully the dealer service department will have a clue (Cross Country Power Sports Metuchen NJ where we bought it in 2015)
  14. #139
    INDIANA, USA
    Default Recall E-mail
    I just received my recall E-mail yesterday (6/22/2022).
    Parts might be available in September was what I was told.
    Hopefully no problems moving forward.
    It is what it is. The waiting begins. ....
    ENJOY YOUR LIFE WITH A SPYDER
  15. #140
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    Default Safety Recall 2015 to 2019
    If this has been posted already, my apologies. I received a letter from BRP today, 6-23-22 advising of a recall on Spyder RT and F3's from 2015 to 2019. The issue is abnormal wear of the front sprocket with potential loss of propulsion. They're offering both a temporary fix in the short term and then a permanent fix once the parts are available. It seems the nasty Supply Chain issues continues in delay of the parts.
    Personally, I've had no issues but will be in contact with my dealer just to stay current.
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
  16. #141
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    both my husband and I have had to replace our front sprockets already, so I hope we're both "ok" until the permanent fix happens. I was kind of happy to see this -- at least that there may be a permanent fix in the works? Wonder what that is and how it differs from what has been done as the temp fix?
    Edit: called the service manager and he said that the already done replacement work is good enough until they learn more about the permanent fix.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
  17. #142
    Mar 2016
    Payson, Arizona
    I have a 2015. I received a letter about this. I have no problem. My sprocket looks fine. Why a temporary fix?
    We all know what the fix is, it has been covered extensively over many years.
    They just need to find competent workers. You need to tell them to learn the correct assembly process.
  18. #143
    May 2009
    Connecticut
    Got my letter- Have had the sprocket and bolt for 3 years since this started and still fine at 23,000 miles .
    Sea Doo GTI-SE 90 Jet Ski!!
  19. #144
    Jun 2015
    Ritzville, Wa
    I got a safety recall noticed in the mail too. But I'm 3,000 miles and several weeks from home so I don't know what it says. But whatever short term/long term measures they have in mind I'm going to get them done.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  20. #145
    INDIANA, USA
    Default Recall Notice
    I received the Email from BRP yesterday (6/22/22).
    I am going to wait until the real fix is available. The Dealer said that the parts should be available in September.
    Enjoy your Ryde Time......
  21. #146
    Oct 2011
    Kalamazoo, Mi
    received my recall letter today. Leaving for a 4-5000 mile trip in the morning!!
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
  22. #147
    Mar 2021
    Haven, Ks
    Received my notice of recall in the mail today. It reads as if the temporary repair does not involve the replacement of the front sprocket but something else undisclosed and the permanent fix involves the replacement of the front sprocket with a new model yet to be produced. So long as my bike is staying functional, I think I would want to be later and not sooner in the replacement process just to be sure that the "new" sprocket really is ok and not yet another mistake. Interesting that the recall does not involve the 2020 and newer models. I could swear that there have been reports of sprocket failures on the new models also. I plan to wait and see.
    Bartender
    2022 Spyder Sea to Sky
  23. #148
    Quote Originally Posted by Bartender View Post
    I'll bet it is pulley removal, thorough cleaning, new correct Moly paste, and proper torquing of a new bolt ..... Mike
  24. #149
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    In the for what it’s worth column, in a conversation with BRP rep on 6/22, I was told ALL 2015 - 2019 RT and F3s are affected by this recall. This was also confirmed by a call to a larger dealership in Northern NY and a local smaller dealer today. The BRP rep suggested I not ride because of the loss of propulsion issue caused by the issue of the recall. I have checked several times and no ‘magic red dust’ visible… BUT for sure I’ll keep checking!!!
  25. #150
    Phoenix
    You do not have to be notified for your Spyder to be repaired in a manufacturers recall
    Quote Originally Posted by PaladinLV View Post
    Were YOU contacted?
    If not your vehicle was NOT recalled.
    Recalls REQUIRE they contact you. Looks more like YOU fond the recall.
    If anything like a CAR they will NOT service your Spyder.
    AJ
    This is not true....you can call and see if you are affected; what if you'd had a change of address or the letter never came....RT' and F3's from 4/15/2014 to 4/15/2019 - BRP plans to notify owners of F3 and RT from 06/20 to 6/27/22 - you can also go to NHTSA.gov - click on RECALLS and THEN input your VIN and it will give you the recall number if you are affected.
    NHTSA campaign #22V-352 Manufacturer recall # 2019-10
    Any questions call BRP 1 888 272 9222 or consult
    www.can-am.brp.com
Tags for this Thread
