Results 1 to 6 of 6
    Jan 2020
    New York
    Default 2020 RTL Side Luggage Release Handle Broke - how hard to change one?
    So I guess I ate my wheatys and I managed to tear the luggage handle off on the drivers left side luggage compartment.
    It had a little resistance, so I stopped, jiggled the door a little and tried again and it just snapped.
    That said, has anyone changed one of these before?
    and if so, what is involved?
    I am going to start tracking down parts shortly
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Jan 2020
    New York
    Just looked at the parts diagram here
    Ordered Part #175 708301222 - LH Control for $40
    Aug 2012
    Central Ohio
    I have to push on one side of mine to get it open. Dealer said no problem. I’ve tried to lube and adjust but still works hard.
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    O believe there is a service bulletin.
    Call your dealership
    Jan 2020
    New York
    So changed the handle assembly this past weekend.
    For starters, you need to disassemble the whole rear of the machine!
    I stopped at the point where I could squeeze my hand into the space with a T27 torque to get the handle off.
    For clear access you would need to remove a ton of plastic on the frame under the seats and I just was not up for that.
    The cause of the failure was what appears to be apple seeds. No other signs of animal life, but something decided to hide its treasures in the handle assembly.
    Will blow that out after storage from now on!
    Quote Originally Posted by AdmiralS View Post
    Consider yourself lucky that BRP even sells the handle as a separate part ..... Mike
