Results 1 to 4 of 4
    Nov 2019
    Kansas
    Default 18 F3L Shifting input
    So I have noticed something. When I am speeding up from a stop, and I shift, if I have the throttle steady and not moving it shifts quietly and effortlessly.
    If I am increasing speed with increased throttle, sometimes the bike will slightly kick as it shifts. it is rare. Probably 1 time out of 30 shifts, but I do notice it. But only when I am increasing throttle.
    It never happens if the throttle is steady.
    Has anyone else experienced this and call it normal?
    2018 F3 Limited
    Feb 2020
    CT and ME
    Normal!
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Quote Originally Posted by acdcking12 View Post
    I have Drag raced both the V-twin and the 1330 .... with an SE trans. .... all shifts are with Full throttle, never noticed any type of hiccup .... JMHO ..... Mike
    Apr 2020
    Edgerton,WI
    Yes, normal.
    The transmission uses straight cut gears, so…..I believe you’re feeling the Engine/ Transmission adjusting to accomplish shifts “smoothly “. Input shaft and output shafts turning at different RPM’s ……ECM and TCM make very quick adjustments to accomplish a shift.
    I was startled too when first experienced…….
    2019 F3L , Covid Blue
