How much oil should drain from Trans plug at Oil change?
On the Transmission oil drain, how much oil comes out? I'm only getting about an egg cup full, is this normal?
Reason: ?
I got more than that but it will vary
Although the engine oil and trans. oil function as one. It's only when the engine is running.... when the system is not pressurized ie. in use ..... the oil does not transfer to each other. .... they will be separate - and the trans. holds way less oil..... jmho .... good luck .... Mike
