Results 1 to 10 of 10
    Active Member Escorial's Avatar
    Jun 2021
    Chicago il
    Question 2020 RTL Does it have a USB port in the frunk?
    I found the frunk light but no port, looked in the manual and saw nothing , I guess the answer would be no?
    Just double checking.
    TIA
    Dec 2020
    Hartwell, Ga
    Mine has one in the trunk but nothing in the frunk.
    Jun 2021
    Chicago il
    May I ask where ?
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Escorial View Post
    May I ask where ?
    In the Trunk with a T! Have you not LOOKED in there? If your Spyder is a 2020 RTL, ITS in THERE!
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    You can add a USB port to the 2020+ RTL frunk if you'd like. By the battery there is a hole in the cover plate to add a cigarette lighter outlet. I read where there is a direct connection that can be used behind the opening but I just connected it to the battery. Once the plug is in you can use a USB adapter. I have an air pump that needed the outlet. Took about 15 minutes to install.
    Jun 2021
    Chicago il
    Too funny, as I asked about the frunk ( front trunk) as they call it on here..
    The actual trunk is a no brainer.
    Jun 2014
    Kansas
    I ran out to the garage and snapped a picture of where you can add the outlet.
    Jun 2021
    Chicago il
    Many thanks!!!!!
    Oct 2021
    Wichita, KS
    Thread hijack here but my 2022 RTL does not have a frunk light. There is one in the trunk. Should it?
    Peter Pan has struck again!
    Jun 2021
    Chicago il
    I had the same thoughts, till I turned the bike on and opened the frunk.
    May also work w ignition just switched on.
    That is on 2020
