Results 1 to 11 of 11
    Apr 2022
    GA
    Cool Used the water meter hole for Baja Ron bar R&R
    I pulled the lid off my water meter hole in my yard, and it appeared to be close to deep enough to get the old sway arm out, and install the Baja Ron. It required just a bit of additional digging, but it worked like a champ. Just thought I'd post it for others to consider, or maybe look for other options. Bar is installed, and short test drive went well. Going to test it out more later today.
    2017 SPYDER RT LIMITED
    Sep 2020
    Middletown, NJ
    Necessity is the mother of invention!
    2020 RT base , Chalk White
    Northern Kalifornia
    Finally got it after the third read. LOL Good job dmiles.
    Apr 2022
    GA
    Yes it was hard to describe what I did, and I could have done a better job. I was just mentioning it so others might think outside the box. Honestly, even if I had to dig the 2 foot hole from scratch I still think it would have been easier than raising my Spyder that high. I actually got the idea from an older post from a member of this board who used his driveway drain. The house I grew up in had a drain that would have been perfect for this. But it is 6 hours away, and my water meter is right here.
    May 2023
    Tucson, Arizona
    I normally use my water meter hole for dumping used oil.
    Last edited by Peter Aawen; 05-09-2023 at 06:41 PM. Reason: Removed big blocks of colour to allow reading by all...
    Harrington, Australia
    Clever, Dmiles, very clever ……. Many thanks
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2013
    Central Texas
    Quote Originally Posted by brian10x View Post
    Now that's probably not a great idea environmentally and all. But it probably gives the meter reader fits.
    Last edited by Peter Aawen; 05-10-2023 at 08:02 AM. Reason: Fixed quote display ;-)
    That's called 'Recycling'... Isn't it? Or is that when you ride your bicycle twice in one day? It's getting so confusing these days.
    Last edited by Peter Aawen; 05-09-2023 at 06:38 PM. Reason: Fixed quote display ;-)
    May 2023
    Tucson, Arizona
    No, when I ride my bicycle I'm rotating my tires. I'm no longer comfortable in the world I live in. I wonder if its a byproduct of getting old. Speaking of byproducts, I have to use the bathroom again.
    Last edited by Peter Aawen; 05-09-2023 at 06:37 PM. Reason: Removed big blocks of colour to allow reading by all...
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Your ride comes with a water meter hole? Was that factory or optional?
    2021 RT Base - Petrol Blue
    Quote Originally Posted by dmiles View Post
    I've heard of a lot of different ways to do this install. But as far as I know. This is a water meter hole first! Congratuations!
