Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Back and neck pain after Ultimate seat - anyone else? Fix?
    So, just throwing this out there. I put an UltimTe seat on my 2021 RTL, and now I have a little pain in my upper back and neck. So I feel like I need to bring the handlebars back, but not up. Has anyone else experienced that?
    Am I thinking about this right … back without raising them? Is that even a thing?
    Thanks
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Sep 2020
    Middletown, NJ
    Lots of options. Heli-bars give total positional control but are $$$ and there's a huge assortment of other spyder bars.
    What changed in your seating that created the new pain?
    2020 RT base , Chalk White
    Jun 2016
    Harrington, Australia
    You can loosen the clamp bolts and rotate the bars on the ‘21 RT, Mike……..
    BUT…… if you rotate the bars toward you, that obviously lowers the height of the bars. Also, there is a slot in the base of the stock bars that limits the amount you can rotate them. If you want to keep the bars at the same height as current, but bring them toward you, your cheapest option is risers. Lamonster, for example, sell a riser block that lifts the bars around 2”. If you install that, and then rotate the bars toward you, you should come pretty close to achieving what you are after.
    As Ray mentions above, Helibars are brilliant with the 4 adjustments, but they are pricey.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Middletown, NJ
    Note that rotating the bars down will also change your wrist angle which could be a concern. I bit the bullet and installed Heli Bars for the flexibility of positioning.
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by Mike0123 View Post
    Thanks
    If you bring the bars back you will be retracting your scapula (shoulder blades). That will increase the pain in your upper back and probably increase neck pain. The way to test this without changing the position of the bars is, once you feel the pain, stop, release the handle bars, and retract (bring back) the scapula and protract (bring forward) and notice which position increases or decreases the pain. You don’t happen to elevate your shoulders when riding, do you.
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    how soon after you started riding your Spyder did the Pain start ?? because I have kinda same problem , but I just thought it was because I grip the Handle Bars way to tight I know , I have been really trying to relax more , but I know its hard to do , I sure want to hear what if anything helps you with your pain.
    2011 RTS Spyder
    Sep 2017
    Durham,Maine
    I think that your seat has maybe lifted you up some and making you hunch over, you may have to raise them up!
    2012 RTL , Pearl
    Jun 2016
    indpls in
    put the f3 stock bars on
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Quote Originally Posted by fatboy View Post
    I had the same problem and this worked for me.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
    Quote Originally Posted by sledge View Post
    .... I no longer even GRIP the bars .... fingers not holding just resting .... UNLESS I'm in the twistie's ...... I guide my Spyder not really steering it ....... way less fatiguing ..... good luck .... Mike
    May 2020
    Rhode Island
    I think after my first 2 hours, but I really didn’t think about it much. Then second looonger ride for me was Friday, 175 miles with one stop, and the pain is back. Not horrible, but I started thinking about it.
    Then after reading these replies I did the same ride, but home. When I felt it I moved my hands off the bars, just leaving my fingertips, so somewhere about 2” up and back. That might be the answer, or at least convincing enough to give it a try.
    Jun 2016
    Then after reading these replies I did the same ride, but home. When I felt i I moved my hands off the bars, just leaving my fingertips, so somewhere about 2” up and back. That might be the answer, or at least convincing enough to give it a try.
    Mike, if you are sure it is your arm/hand position causing the issues, you should seriously consider the Helibars if finances allow. They will let you go up and back, and adjust the wrist angle for the best comfort.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2021
    PA
    HeliBars was the best investment in my bike so far.
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    HeliBars and Utopia driver backrest worked for me.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    May 2020
    Rhode Island
    Thank you all. I'll look further at the Helibars ... but I don't think I'm $600 sore, but I do appreciate where you are coming from. I usually try to ascribe to the "pay once, cry once" school of thought, but our finances wont allow that right now.
    Thank you all for your input and things to think about. I'm going to take a ride and try all the suggestions.
    Sep 2014
    USA
    Did you get the backrest with your seat?
    Jun 2016
    Fair enough, Mike…..and I have seen a couple of pairs of Helibars for sale as they didn’t work for their owners (not sure why), so they don’t work for everybody, just nearly everybody . I would hate you to spend that money and then find that you are one of those riders. Mind you, there is always a market for 2nd hand, so they can be sold easily. Good luck in finding a resolution
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    indpls in
    if that seat raised you up might want to raise the floor boards also
    Aug 2019
    Stoughton, WI
    Pete
    I wish I could have found a used set, but I was lucky enough to wait until the taller 2022 F3 version came out. After elongating the hole a touch, I can damn near make them mini apes
    2022 RT Sea To Sky
    Active Member scorpion56's Avatar
    Jun 2020
    Boston
    I have an ultimate seat on my F3. I love it but it didn't eliminate the neck/shoulder pain. That was solved by purchasing (directly from CanAm) and installing Short Reach handlebars. Pain is gone. If that hadn't worked, my next step would have been the more expensive Heli-Bars.
    2019 Can Am F3 Limited
    Spyder Upgrades/mods:
    F4 Windscreen,
    Ultimate seat and Driver's backrest,
    Lamonster Fog lights,
    Lamonster Brake Rod kit,
    CanAm Short Reach Handlebar
    Other Current Bike: 2009 Honda Shadow 750 Aero
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    2019 F3 Limited , Oxford Blue Metallic
    Danbury Connecticut
    I'm coming late to this thread. I seem to be doing that a lot lately................
    Regardless, I vote strongly for Helbars.
    Quite a bit of cash up front, around $650.
    Nevertheless, the best investment I made on my 2020 RTL.
    I had my dealer install them even before I picked the bike up.
    Infinite adjustment in all planes. You even have the possibility, if necessary, to adjust the left side and the right side independently.
    I also got the BRP backrest.
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Member Jbird's Avatar
    Dec 2020
    Jonesboro, AR
    I do like taller bars on my bikes, but with the position of the mirrors, i am concerned that the Helibars are going to put my hands right in the view of the mirrors.
    I have my F3 bars lifted about a high as i can go and see my mirrors just over my wrist. If anything i would like to go higher.
    Can you folks that have the Helibars tell me if you can see your current mirrors, or did you have to add new mirrors? Thanks
    2021 Limited , Lava Red
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Jbird View Post
    I have the newer/taller version of the Helibars on my F3S. Yup .. They do block the OEM mirrors. I have Lamonster Top Cuffs/aftermarket mirrors on the byke now.
    2022 RT Sea To Sky
    Feb 2020
    CT and ME
    To the OP, try giving yourself a few weeks with the new setup before you buy anything. Sometimes it takes your body to get used to the changes but eventually you will. Just like when I got my bike and it took a few weeks for my arms to settle in.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Sep 2020
    Middletown, NJ
    I have the HeliBars on my '20 RT. No problem seeing mirrors. I'm 6 ft. on OEM seat.
