Results 1 to 20 of 20
    Dec 2020
    Las Vegas
    Default RPM shift points
    Ok, I have had my 2021 Spyder RT Limited for about a month and 1000 miles now.
    Have stopped looking the front brake lever and have started the process of spending money on things to make it mine.
    But I am still wondering about RPM ranges and shift points.
    I have followed the simply hold the throttle position and shift directions that I have read here and elsewhere (instead of roll off to shift like a manual clutched bike) but excepting the 3400 - 4400 rpm range the gear change is noticibly jarring (smooth as silk in that range).
    So...
    1. In normal riding (not hard acceleration) where (rpm) are you shifting?
    2. Above the 4400 rpm range; is the computerized electronic throttle rolloff and re-engagement expected to be jarring?
    3. What rpm range do you attempt to keep the engine within while steady state cruising? I find myself wanting to get to top gear and then realizing (around town speeds) that I am too far out of the powerband for immediate response.
    I have no issue with rpm if I should be winding a little higher - my wife appreciates the smoother (less to and fro) shifts at lower rpm.
    But I also want to break in and make sure I am operating the bike for its optimum performance.
    Feb 2019
    Portland, Oregon
    The secret to smooth shifts is hold the throttle absolutely still when shifting - do not close the throttle when upshifting. It's OK to close it when downshifting to a stop. I assume you have a semi auto, you didn't say.
    When accelerating hard, you can grab over 6K RPMs.
    Feb 2022
    Washington
    VegasDan
    I shift per road conditions and down shift rather than braking. In reading much I think the rotax engine should be reved and shift around 5500 rpm. My fuel mileage dropped using that method. I shift at lower rpm and don’t roll off for a shift either up or down. My Spyder likes a steady state ride for best mileage. Don’t know any other results from the long term riders on this forum.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    When cruisin, I keep the rev's around 2500 rpm, upshift to cruising speeds just around the 3000/3500 rpm's, whilst driving solo, rpm's usually lies around the 5000 rpm's
    the 1330 is a mighty motor, and likes it both ways, It loves to cruise, but also wants to be drivin hard... depends on the mood you're in...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    For normal cruising ... I use 2500 to 2700 RPM's ..... Mike
    The "sweet spot" for our spyders (1330's) is around 3500 rpm's. The 5500 shift range was for the 990/998's.
    I find smooth, noiseless shifting when shifting in that range. I let my spyder downshift at will. I try to run 3500 in all gears, except for sixth. Based on the speed over 55, the rpm's will go where they want. Best mileage is maintained by keeping it in the 3500 rpm range. I get high 30's/low 40's on mine all the time.
    Feb 2016
    I too, shift at about the 3000 mark. Do a search here for the 1330 torque chart. You'll find there's no reason to constantly wind this engine out. The vast majority of the torque comes on earlier than you'd think. After awhile, you won't even look at the rpms when doing normal driving; you'll shift by sound and feel.
    2020 RT Limited , Marsala Red
    Northern Kalifornia
    Absolutely, sound and feel.
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    hardly ever go past 3,500 RPM ... unless I'm getting on a freeway on ramp with cars going by at 70+mph
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    I strongly suggest you thoroughly read your operator's guide. The 1330 engine is not going to let you lug it so it will not let you upshift below the rpm points the engine control module is programmed to for each gear.
    Northern Kalifornia
    If you like shifting above 3500, say 6500. Get stage 2 and a seatbelt to go with it.
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    My dealer recommended 3100 rpm's, but I've found that around 3500 is the smoothest. When cruising at a constant speed, I stay around 27 to 2800. It's all about feel, and what riding style is right for you.
    2021 RT Base - Petrol Blue
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    For normal traffic in city 3000
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Just some numbers here, Your stock 1330 has a redline of 8100rpm, by adding a PV3 you go to 8400rpm. Now with the Monster flash 1&2 your at 8600 to 9200rpms.
    your not going to break it, But it's there if you need it! your gas milage will suffer the more you twist it.
    I'm guessing that most people will never hit that 8100 and those with the monsters don't always go to the top. Just ride it and don't worry about RPM's
    T.P.
    Quote Originally Posted by T.P. View Post
    T.P.
    My experience is a bit different .... I've drag raced my 14 RT at a track and found that 6000 rpm's was the sweet spot for up-shifting. .... after 6000 the torque curve was dropping, so the gain in HP didn't improve things ..... my 11 RSS V-twin was different .... JMHO .... Mike
    Oct 2021
    Ontario
    Torque gets you there, HP keeps you there.
    This is history but perhaps of use as general knowledge.
    Ontario Canada
    I have to agree and slightly disagree with some of the advice. I also listened to others when I first got a spyder and I kept the throttle steady when up-shifting. I found that was fine for gentle and normal acceleration. If you are pulling hard there can be quite a clunk when up-shifting. It may not hurt it but I don't like it. If I want to accelerate hard I will roll off the throttle a bit just before up-shifting. Once you learn the timing the shift is smooth with no clunk. As far as RPM, I don't worry about it. Stay in the power band and it will feel fine. Not good to lug it and no need to rev it to redline.
    2022 RT-L , Carbon Black - Chrome Trim
    Quote Originally Posted by WingManDan View Post
    Read my post #$ 15 above ( I never roll off the throttle - " you snooze you lose " in Drag Racing ...... if you are encountering a loud clunking I think something is failing in your transmission ..... good luck .... Mike
    Ontario Canada
    Yeah, to each their own. There is nothing wrong with my transmission. I'm just offering a different perspective to the OP. I like the smooth way it shifts better under hard acceleratinon if I coordinate a quick throttle reduction when hitting the shift button, especially 2 up. Not trying to be a drag racer, just enjoy the ride.
