Results 1 to 4 of 4
    May 2022
    Tennessee
    Default Looking for a Grommet 2011 RTS
    My new to me RTS is missing the grommet on the front panel (access to oil reservoir). Does anyone know where I can get a replacement, or the part number?
    Feb 2019
    Portland, Oregon
    I'd try Ace Hardware first. Most grommets are not proprietary.
    The thick oval rubbery type grommets that the placcy pins on some panels slide into can be sourced fairly cheaply from cheapcycleparts & similar, or from BRP for not too much more! Sorry, but I can't recall any part numbers or their BRP name, but you should be able to find them on the parts diagram - doesn't really matter where you find it, they are either oval or round & once you've got the correct shape they are all basically the same size. Buy a few new, fit where necessary, & then either silicone them in or add a small zip-tie & keep the rest as spares - you certainly won't lose any more that way!
    May 2022
    Tennessee
    Thanks for the advice, being an older bike I was worried about easily finding the part. 3.00 each, I bought a few lol
