Results 1 to 25 of 28
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Has anyone put a cargo carrier on their trailer hitch?
    Has anyone put a cargo carrier on their trailer hitch? Wondering what it looks like, and if it made the byke drive any different? Thinking it might be a cost effective way to NOT have to buy a trailer. Pics if you have them!
    Last edited by Peter Aawen; 05-12-2022 at 02:55 PM. Reason: Removed Prefix - this is a 'How do I?' not a 'How to:' DIY explanation....
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Dec 2020
    Hartwell, Ga
    I have not but keep in mind that the weight will be limited to only 40lbs doing this. At least that's what the max tongue weight should be.
    Dec 2020
    Hartwell, Ga
    Another thing, the 40lb limit will include the weight of the carrier.
    Clinton, MS
    Also the tire will be the only thing softening the blow every time you hit a bump.
    May 2017
    Mesa, Arid-Zone-A
    I just installed one on my Goldwing/CSC Trike today. It is Universal Motorcycle Trailer Hitch Rack from Big Bike Parts. The quality, fit and finish exceeded my expectations. It's not very big but I have a Kuryakyn Bag that fits perfectly. Unlike the Spyder, my trailer hitch is attached to the sprung bike frame. My plan is to carry bulky items like rain gear and bike cover in that bag. It has a 2 pin quick-disconnect so I can quickly pull the rack, bag and all, off the bike for overnight motel security. My only potential concern is the possibility of dragging the rack on steep driveway transitions. Knowing that, I think that can be eliminated by transitioning driveways at an angle. I have been looking and considering one of these for a couple of years. At one time they were about $100.00. But like everything else, the price has gone up. It was now closer to $150.00 by the time I paid tax. Hope this helps..... Jim
    Semper Fi
    May 2013
    Apex, N.C.
    This is the Doc Humprey's rack that he used to sell. I love it. In the picture from the rear, it appears to conceal my license plate, but this was before having my air bag replaced on my F3T. I also used this on my 2014 RT. Works great and holds enough clothing for 2people for 5-6 days easily.
    Bossier LoUiSiAna
    9F39D3A2-B4E5-4CD6-9EF6-146A4F94F2FD.jpeg https://pakitrak.com/ do have to contact them for spyder parts
    (apparently remove from webpage)
    Also Jt has the NHR https://spyderstore.com/index.php?ro...tegory&path=66 was a vendor on home page
    Jun 2018
    HAYMARKET,VA
    This is perfect! How did you mount it to the hitch?
    Baja Ron Sway Bar
    Key Cover from Ebay
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Some members have used the Pakit Rak, https://www.spyderlovers.com/forums/...hlight=pak+rak
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Aug 2018
    Piperton, TN
    I love this idea. How does the heat from the exhaust effect things. Does the exhaust blow back on the contents mounted on the hitch?
    May 2013
    Apex, N.C.
    Quote Originally Posted by FINFAN3DP View Post
    There is a nut that I used through the hitch where the ball would be, and it also had 4 U bolts that held it in place.
    May 2018
    Chateauguay, Qc, Canada
    This increases the unsprung weight of the rear tire of you bike and will adversely affect handling. Not recommended for performance oriented riders.
    On Goldwings the hitch is part of the sprung assembly so the road compliance of the wheel is not effected.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    May 2013
    Apex, N.C.
    Quote Originally Posted by ollicat View Post
    Mine had a plate that deflected the exhaust below the rack.
    Bossier LoUiSiAna
    9F39D3A2-B4E5-4CD6-9EF6-146A4F94F2FD.jpeg1873AE8D-EDEF-40F9-9011-32F04DAFF067.jpeg https://pakitrak.com/ do have to contact them for spyder parts
    Where’s the pics??**one more time:
    additional info pack it rack bag - bout same size as frunk,has rain cover, can lock to rack& detach to come in hotel or whatever also wanted Doc’s rack; waited too long & missed out, found used Packitrack good price. Allows more than normal & less than trailer.
    Also more info:
    https://www.spyderlovers.com/forums/...r-hitch-for-RT
    Last edited by Bfromla; 05-14-2022 at 11:41 PM. Reason: *Pics were missing, then appeared¿*
    Good idea in theory. As has been said the hitch is mounted solid to the swing arm so there is zero cushioning from road vibration and bumps. That means anything fragile is going to get mashed. You only want to carry very durable, and preferably light weight, objects in it, because they will bounce.
    The Doc Humphrey's unit is no longer available. Doc departed the site, along with all his products, several years ago. I don't like the way the Pak-It unit hangs far behind the hitch. That'll just increase the bounce it is subjected to. If you're handy get a sheet of aluminum deck plate and drill it for a bolt to replace the hitch ball as well as a couple of saddle bolts to secure it to the hitch arms. Then drill it or add eye bolts to fasten by tie downs something like a duffle bag onto the deck plate
    Dec 2018
    Long Island
    Rivco products has one.
    Northern Kalifornia
    Idaho is correct. In the above photo the distance the rack hangs out over the hitch will increase the torque load on the hitch. The 40/45 lb load recommendation for the hitch load is ON TOP of the ball. Use a fish scale and attach it to the back of your loaded rack and see how much down pressure it actually exerts on the hitch. It may surprise you.
    May 2017
    Mesa, Arid-Zone-A
    That is exactly why I keep heavier things INSIDE the bike and will use the hitch rack for light, bulky things. The total weight of my loaded hitch bag, including the rack is less than 15 pounds......
    Semper Fi
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by LongIsland View Post
    Do you have a link?
    Baja Ron Sway Bar
    Key Cover from Ebay
    May 2017
    Mesa, Arid-Zone-A
    The Rivco rack is essentially the same size as the Universal rack I bought, 11 X 16 inches. They are each constructed a little differently. But size, function, and weight are about the same. You can Google them both to get details..... Jim
    Semper Fi
    Jun 2018
    HAYMARKET,VA
    This would be perfect! But i can't find one for sale anywhere.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Northern Kalifornia
    https://spyderstore.com/index.php?ro...mation/contact
    I don't know if JT is still in business. He has/had good stuff.
    JT is, I believe, pretty much a one man business doing machine work. I'm not sure he ever actually produced any quantity of those carriers.
    Northern Kalifornia
    Give him a call tomorrow.
    May 2013
    Apex, N.C.
    Quote Originally Posted by Eckhard View Post
    I have often ridden with the rack on mine. Once I get to my hotel or cabin, I unload the bag (which only contains clothes), and leave the rack on the bike. It does not affect the handling at all on the bike. Now, I've added a Givi box on a rack at the rear of my 2016 F3 Limited, and I can definitely tell it is there when cornering. It will also be coming off once we check into a room.
