Results 1 to 8 of 8
    Apr 2022
    ME
    Default Bike won't start
    2013 RT
    Engine just stop and won't start. New battery and fresh gas. Cranks good but won't start.
    Is there a fuse that could be blown? Where do I start checking to find the problem, believe in ignition. How do I get to the spark plugs without taking some of panels off?
    Nov 2018
    Waynesboro, PA
    Welcome to the forum Happygramp. I'm not sure if your new to the Spyder or not. so try basic thing first. Sit on Spyder make sure the kill switch is not in the off position. click it back and forth a few times, and leave it in the run position. turn key wait for it to tell you to read card then hit the mode button, Now step on the brake and keep your foot on the brake and push the start button. Any luck? If you are not new sorry to run you through the basic but so many forget at first, me included.
    My Spyder
    2012 RTL , Brown
    Quote Originally Posted by CopperSpyder View Post
    and for Spyders, the only time you don't have to remove " Panels " is when you add gas or check oil .... for all else Tupperware / ie. panels must be removed .... good luck .... Mike
    Feb 2012
    Spring City,Utah
    Actually Mike, you do have to remove a panel to check oil on an RT
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    I was thinking the seat is blocking those caps ........Mike
    Apr 2020
    tucson az
    I would check the spark If there is a weak spark or no spark then work back from there. It could be bad spark plug wires or the coil. The new battery make sure it has a full charge they will drain if set on cement or from sitting on the store shelves as you don't know how long it sat.
    2011 rt , pearl white
    Feb 2012
    Spring City,Utah
    You can't get to any spark plug on an RT without removing a lot of plastic. Since you have a VTwin you have to do both sides. For the rear plug pretend you are doing an oil change. For the front plug pretend you are doing an oil change but on the right side and also remove the entire air box/filter.Good luck.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Bossier LoUiSiAna
    Ummlooks like a hit & run posting
