Car tire pressure 2011 Rts Limited
I put Altimax RT43 tires on the front and rear of my 2011 Rt...If anyone is running these or another car tire, would you please tell me the psi you've had success with?
Thank you...Kevin
19 or 20 PSI all around and adjust from there---------
I’m 16 lbs on the front (Vredesteins) and 18 lbs rear (Altimax43)
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Both Peter Aawen & I ( tire science proponents ) agree this PSI is what works for ALL Auto tires ..... adjust one up if you are aggressive or are near the weight limit for your Spyder, Towing is not a factor ...... good luck
Coopers on the front and Pirelli on the rear 16psi front 20psi rear on a 2012 RTL
Reason: a2012 ;-)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
