Ryker 900 first oil change: debris in filter housing
Just finished my first oil change on my 2021 900. Upon removal of the old filter, examination of the bottom of the housing revealed pieces of dark grey rubber-like material. I'm thinking maybe it's excess gasket-forming material (e.g., Permatex). I can confirm that it is NOT part of the old o-ring nor part of the seal on the bottom of the old filter. Should I panic? (The old o-ring is partially visible in the image, for scale).
I would take THAT to a dealer and ask them.
That does not look good at all!!
Good reason to get that initial service out of the way. Not uncommon to find some industrial leftovers, and the earlier you catch any such suckage, the easier to limit any damage AND get it covered under warranty. Just got my 900 Ace back from the shop with a clean bill of health.
That said, I'd rather find something like that instead of metal shards, right?
The nations best ... ALL THE WAY!
Any debris come out the drain?
23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
2020 900 , NGK 4218 iridium CR8EIX Matte black
No, nothing.
I seriously doubt my dealer would take the time to inspect/clean the filter housing or check the old oil for debris. That's just me, though.
AIRBORNE!
If no debris came out the drain, then I would expect:
1. The oil filter caught the debris;
2. or most likely due to size, the debris originated in the oil filter housing and went no further
You may want to change oil and filter again shortly for peace of mind.
