Page 1 of 2 12 LastLast
Results 1 to 25 of 37
    Dec 2021
    New Mexico
    Default 2021 Spyder RT not starting - any ideas?
    Hello. Sorry for the lengthy post.
    My wife just got a used 2021 Spyder RT with 1700 miles from California with still the factory warranty and my wife drove 800 miles to get home. After my wife went to register the RT, we were going on our first ride together with mine. We tried to start it and all kinds of things lite up. The instrument panel it come up with VSS, key not recognizes and trunk open. When we try to start it the Spyder, it would crank for about a second and nothing and the instrument panel would start blinking and heard a clicking noises. I can’t even get to get the codes from the settings. Then we couldn’t see anything except the warning lights. The battery is tight with star washers and the oil is at the correct level. We called for a tow and went to get something to eat at a nearby restaurant figuring if we left it alone for a bit it would do something different, it did the same thing as before. A few times it would start but shut back down. We got it home and parked it and covered it. We did followed the correct start up and had out foot on the brake. I have looked here, google and YouTube. Is there anything else I could check?
    I was a mechanic for 20 years so I’m pretty handy around things. I have a appointment middle of next month at the dealership. This weekend I’ll be going to my first meet up with a spyder group and will ask questions and see if anyone has a BUDS tester and willing to come to my house to at least get the codes.
    I think I covered everything. Tomorrow I am off so I’m gonna check a few things.
    Charlie
    Last edited by Peter Aawen; 05-09-2022 at 02:51 PM. Reason: Removed prefix - not a product review
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Fault codes can be found on your display at the very end of settings
    Oct 2020
    Vinton, IA
    I always start w/ the easy stuff. As odd as this may sound given your RT is a 2021..., fully charge the battery, then load test it. My 2020 lights up every time I run the battery down while listening to the stereo.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Dec 2021
    New Mexico
    Hello, in my post I can’t get that far to check the codes, I know where they are at. However I will check the battery. Don’t have a load tester. Could I take the batter to autozone to get load tested?
    Idaho
    Your battery is shot. When you hit the starter button the output voltage drops below 10.5. At that point all the computers go bonkers and the engine won't even turn over. Not like the good old days when a half-dead battery would still crank over the motor.
    2014 Copper RTS
    Sep 2016
    Chillicothe, Oh.
    My first check would be the battery also. Just because the bike is a 2021 doesn't mean the battery is.
    2015 RT , Black
    Dec 2021
    New Mexico
    Thanks, that does make sense. Could I just goto autozone and get it checked. If it’s the battery could I just goto a local motorcycle shop for a battery.
    Oct 2020
    Vinton, IA
    Most (national chain) auto parts stores can load test; whether or not they have a battery for the RT is another question.
    IMHO, don't cheap out on a battery; the advanced electronics on new vehicles draws heavily on a battery, and, as mentioned above, "the computers go bonkers".
    Dec 2021
    New Mexico
    Thanks for all the replies. I’ll update tomorrow. I love it here.
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    i had to put a new battery in my 2021 RT this year. Even with a tender on it all winter it said no way and my lights went nuts also.
    Idaho
    Quote Originally Posted by cwhowardjr17 View Post
    You can do a load test yourself on the cheap. Connect voltmeter to the battery, open the throttle all the way, press the starter. If the voltage drops badly you know the battery is no good. Holding the throttle open keeps the bike from starting.
    2014 Copper RTS
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    I am not a qualified mechanic but have been turning nuts for 50yrs and maintaining all my vehicles along the way so I guess I have picked up 1 or 2 mechanical skills along the way...
    A simple multi meter is relatively cheap. For the price of taking it somewhere and paying for it to be tested its probably cheaper to get a multi meter.
    Dec 2020
    Hartwell, Ga
    Auto parts stores here in the USA normally do it for free.
    Honestly, I've never saw one charge for this.
    Sep 2014
    USA
    Check the connections first maybe they are just loose??
    Dec 2021
    New Mexico
    That was the first thing I check and even put star washer on them
    Idaho
    Go wherever you can find one. The general consensus is for the money it's hard to beat the OEM Yuasa, YTX24HL. If you get the version where the acid is in a separate container be sure to let it sit for a day or two before charging, and then charge slowly at 2 or 3 amps until the charger shows full charge. Even if you get a "ready to use" one put it on a charger for several hours. Proper prep goes a long way to assuring a long life out of the battery.
    2014 Copper RTS
    Dec 2021
    New Mexico
    I was able to pull the codes U1150, P2301, P2307, P2304, U0100 AND C006C
    Oct 2020
    Vinton, IA
    And the battery???
    Idaho
    I was able to pull the codes U1150, P2301, P2307, P2304, U0100 AND C006C.
    I'd forget about those codes. When the battery is bad and the cluster goes bonkers you can get all kinds of meaningless codes.
    2014 Copper RTS
    Sep 2016
    Chillicothe, Oh.
    I was in a pinch and AutoZone had a Duralast for the Spyder. Two years old and working great. I keep it on a tender and I have a volt gauge on my Spyder.
    2015 RT , Black
    Sep 2017
    Durham,Maine
    X2
    2012 RTL , Pearl
    Sep 2016
    N.E. Ohio
    Yes, like everyone has said: battery. I started the Spyder (2020 F3L) 2 weeks ago and decided to get a jacket. Shut the Spyder off, got my jacket and turned the key on. Display started flashing, VSS code, exclamation mark and other weird displays. took the battery out and took it to my mechanic neighbor. He checked it out and said "it's got a dead short." Spyder only has 5K mi on it and is only a year old, I bought it as a left over. Got a Yuasa, $108 and 3 day delivery from amazon. Installed it and everything's back to normal.
    Sep 2017
    Durham,Maine
    Glad you got it fixed!!!! So many people get all hung up on the age of a battery and don't want to get it load tested, they can be bad right out of the box, and at most auto parts stores they will check it for free!! Good job!!!
    2012 RTL , Pearl
    Mar 2013
    The clicking sound got me thinking about what happened to my 2020 RT. Turned out to be a blown fuse. There are two fuses that tie to the starter not sure which one to was as the mechanic who fixed it was off the day I picked it up. If your battery tested ok I would check your fuses.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2021
    New Mexico
    Something came up and I couldn’t test the battery. I’ll take of that tomorrow and check the fuses
