Results 1 to 10 of 10
    Aug 2019
    Stratford Ontario
    Spyder Anyone installed Phone Charger USB Port....in Toggle switch area???
    Has anyone ever installed a USB phone charger/USB port in the centre position of the Toggle switch area where your toggles for the lights, heated grips setting, etc. are located? I have a 2015 CanAm Spyder RTS.
    thanks...
    Feb 2017
    Can't speak for all providers of Spyder stuff, but Pierre at canamspyderaccessories.com sells what you're asking about and has a nice installation video as well.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Aug 2019
    Stratford Ontario
    Thanks! I will check it out... He has some excellent videos!
    Oct 2015
    Lynden, WA
    I installed a voltmeter and dual USB port in that location on my old STS.
    Bought the device on Amazon. Exact fit to the switch blank.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    That's where I put mine.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Active Member rv6a's Avatar
    Mar 2021
    Indiana
    I installed a dual USB port and voltmeter in my 2021 RTL. The problem with the 2021 RTL is that the hole in the dash is longer than "normal" plugins for autos. I think the hole size changed in the 2020+ models. I did find an adapter for $8 on eBay.
    Feb 2012
    Spring City,Utah
    I used the dual port charger from Pierre at canamspyderaccessories.com. It looks and works great and was easy to install.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Yep, that's where mine is as well.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Northern Kalifornia
    There's a great video on this site of exactly how to install that USB port.
    Aug 2019
    Stratford Ontario
    Pierre's video was excellent. We followed it and the install went really well!
Tags for this Thread
