Results 1 to 6 of 6
    Feb 2020
    Indianapolis
    Default Need instructions on Parking Brake Sensor/Switch Interrupter replacement? Help??
    2018 Spyder f3 SE6
    Can someone instruct me on how to replace the parking brake sensor that’s on the front right knee side of the bike parking brake light won’t go off and it beeps. The sensor seems to be mounted with what looks like metal pop rivets any advice on how to remove it?
    Nov 2022
    Oklahoma
    I too need ideas on how to replace the parking brake switch. Has anyone out in Spyder lover world done this?? My bike is 2011 RT SE5.
    Mar 2019
    Fla/NJ
    pg 664 in manual have you tested switch? if replacing then rivets need to be drilled out
    Feb 2022
    New Zealand
    Quote Originally Posted by F3VE View Post
    2018 Spyder f3 SE6
    Is the brake working?
    Last edited by Peter Aawen; 02-12-2023 at 12:43 AM. Reason: Fixed quote display. ;-)
    Feb 2022
    New Zealand
    Quote Originally Posted by livin4christ2 View Post
    Probably best to start your own thread on your 2011 RT SE5, that way nothing gets crossed up and misunderstood. ie different bikes, different motors, different systems, and different problems.
    eg. sensor v switch
    Feb 2016
    As stated in reply 3, per the service manual, the rivets need to be drilled out to replace the switch.
    2020 RT Limited , Marsala Red
