Results 1 to 13 of 13
    Sep 2019
    illinois
    Default Ryker 12,000? Mile Transmission Warning - when did it show?
    I'm wondering how much odometer variation there is between everyone's Rykers whose had their transmission warning come on. Mine hasn't popped up yet with just under 12,100 miles. What was your mileage?
    May 2009
    Connecticut
    12,200 but I traded it in to start over!
    Sea Doo GTI-SE 90 Jet Ski!!
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    11,760 and I replced the belt myself
    2019 Ryler Rally , Shock Yellow
    Active Member Gundam's Avatar
    Dec 2013
    Singapore
    Quote Originally Posted by Tslepebull View Post
    Hi, how do you reset the transmission warning?
    Dec 2018
    East Texas
    Quote Originally Posted by Gundam View Post
    You can reset the warning if you have a powerbox type programmer. Otherwise it is a trip to the dealer for the BUDS
    Apr 2020
    New Hampshire
    I'm at that point now so I'll change the belt myself, but will need to take it in to have the code cleared. Just a code, no limp mode, correct?
    2019 Rally , BLACK
    Sep 2019
    illinois
    Correct, NO limp mode. My warning did not come on until 12,525 miles. I rode one more 30 mile ride. Then changed the belt and oil over the weekend. Didn't get the 12,000 check for another 450 miles, due to the main water pipe started leaking out in the front yard. Thank goodness I had (& a triple thumbs up to) Pivotal Home Solutions!
    Quote Originally Posted by NHTundra View Post
    I'd try dis-connecting the Battery first ...... this very often clears codes ...... JMHO .... Mike
    Aug 2019
    Florida
    Its going to take years for me to hit 12k miles. I have only 225 on my 22 Rally right now. Traded my 19 in with 2100 miles on it back in December to pick up my new one.
    2019 Rally , Black with red panels
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Quote Originally Posted by Zusafek View Post
    That's O.K.........It's the SMILES per MILES, that really count. Enjoy the ride.
    Apr 2020
    New Hampshire
    Also wondering if it's possible to reset the warning odometer before the code appears. I have a few days off now so I could change my belt and take it to my dealer, but I'm just under 12k so the code hasn't appeared yet.
    2019 Rally , BLACK
    Active Member DickB's Avatar
    Jun 2021
    FL
    Yes. I had to have my CVT repaired at 2500 miles and that included a new belt. Just under 14000 miles now and no message or warning yet - expecting it in another 500 miles. Dealer must have reset it.
    May 2019
    Albuquerque NM
    At 14,500 miles, no warning yet.
