Results 1 to 16 of 16
    Jun 2015
    Hampton Roads, VA
    Default Any ideas to Remove paint overspray from tupperware??
    Here's a new one! In my garage on a shelf an old spray paint can's bottom exploded. Guess it's over 10 years old. It blew across my whole garage and of course my Spyder. Now it's covered with dots of paint. I can easily scrape it off with my fingernail, but we would be talking many many hours. So far a kitchen scrub brush & dawn doesn't get the spots off. I'm wondering if any of you might know a trick? I'm thinking Goo-Gone and a mild scrubby? Any ideas? I was thinking maybe something similar happened to one of you.
    THanks!
    Steve
    Jun 2015
    Ritzville, Wa
    I would be careful about using Goo Gone. I used it once to remove adhesive from the doors on my truck. It worked like a charm. Unfortunately once it dried it left discoloration on all four doors of my crew cab. Luckily I took it to Maaco who was able to buff it all back to normal. I thought I was going to have to have it repainted. Lesson learned.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Quote Originally Posted by stevencovert View Post
    THanks!
    Steve
    google " Kleen Strip " .... it's milder than the normal kind and should do the job ..... I use it to re-move any TAR or Bug debris on my Spyders ..... Mike
    Feb 2020
    Minnesota,USA
    THanks!
    Steve
    Try acetone, worked for me!........Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Jun 2015
    Hampton Roads, VA
    Didn't think of acetone. THanks!
    Jun 2015
    Hampton Roads, VA
    google " Kleen Strip " .... it's milder than the normal kind and should do the job ..... I use it to re-move any TAQR or Bug debris on my Spyders ..... Mike
    Will do thanks!
    Feb 2020
    Minnesota,USA
    Evaporates fast and wash with warm soapy water immediately after getting the paint off!.......Bill
    Oct 2021
    Wichita, KS
    Orange oil. Works a charm and not abusive to paint what-so-ever.
    Peter Pan has struck again!
    May 2020
    E. Central Illinois
    I used a clay bar on overspray on my truck. Black on black truck. Couldn't really see it, just feel it and it was light. Don't know how heavy your spots are or if it will work for heavier spots. But the added advantage is a nice smooth paint finish.
    Jun 2011
    Near Lexington, NC
    I wouldn't use acetone on paint; it might well remove the paint. Thats some strong stuff. At least consider it a "last resort".
    t
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2014
    USA
    Try a light rubbing compound. Yeah I agree acetone maybe ruff on the plastic and paint.
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Try this, very good. Works for polishing with course, medium and fine polishing pads - one product does all three.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    I agree with the clay bar, I own a body shop and it works wonders and will not harm the painted surface!
    Toby
    2020 RTL
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    I was in the residential and commercial painting business for 23 years. There were the occasional instances of sprayed oil-base paint getting blown onto cars is they parked where we told them not to with signage. People would then complain we got paint on their cars. I found that both acetone and residential grade lacquer thinner could be used with a soft cloth without harming automotive finishes of either just paint or clear-coat. We never had a problem with it and did always rinse with soapy water immediately after using either one. Haven't had to do that on a Spyder yet and hope I don't ever have too, but I would think they have as good of paint as most cars.
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
    Active Member ferrasr's Avatar
    Nov 2021
    Alberta
    About 30 years ago someone told me about using Kerosene with a soft cloth, have used it ever since to get tar, oil, tree sap and paint over spray off. Rinse off with a good car wash soap and water, has worked for me. You can pick it up at any hardware or camping store.
    2022 RT Limited Petrol Blue Metallic Dark
    Jul 2016
    Lake Frederick Va
    Dealer uses ez off oven cleaner to remove paint. Don’t leave it on long just wipe immediately. I haven’t done this but saw them take off painted pinstripe.
