What is the Lug Nut Torque meant to be?
Changing my front tires out to Q5's this week (thanks to all that helped with my education) and I realized that I don't know what torque to use for mounting them. I tried "feeling" what came from the factory with my torque wrench but (surprise, surprise) there was quite a difference nut to nut. My guess is about 100 ft-lbs but I wonder if this is something that you folks have wrestled with and solved. Any suggestions?
Ozzie Ozzie Ozzie
Wheel lug nuts 105 N•m (77 lbf•ft)
Thanks. I actually did read the owners manual. Once again I overlooked it.
Frankly, I wouldn't trust the torque values using your method. I had to resort to my DeWalt impact wrench because as I was trying to remove the first lug nut, the wheel started to spin. I'm thinking there is NO WAY it should be THAT tight.
SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2018 Can-Am Spyder RT Limited - hers
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - the dog's
1995 Fleetwood Flair 27R - EVERYBODY'S !
Remember, if you use something like " never-seeze " on the threads ( like I do ) then I'd go with 80lbs. .....JMHO .... Mike
Reason: Remeber = Remember ;-)
Torque for front wheels
Would someone know what torque the front wheel nuts on a 2021 rt is, thanks
2022 RT Sea To Sky
Page 145 in the Operator's Guide 80 ft. lb.
2020 F3L front lugnut torque specs
replacing front tires tomorrow,, is 80 ft. lbs the correct torque,, tks.
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
The specs are 80 + or - 3 so you're good to go.
