Results 1 to 9 of 9
    Jul 2017
    Long Island NY
    Default 2017 F3-L Rear Tire Change
    Hi All,
    I have been doing a lot of searching on here about changing my rear tire and I appreciate all of the great info people have provided. I purchased a Vredestein Quatrac 205/60/R15 tire. I am planning on doing the work myself and I was wondering if anyone has used the Harbor Freight Manual Tire Changer to work specifically with this rear wheel? My concern is that the axle hole diameter on the wheel will fit on the center post of the changer. I tried to find the diameter of the axle to check, but have not had any luck. BTW, I have the original tire on running 28lbs and it has 19980 miles!
    Thanks,
    J
    INDIANA, USA
    Default Original OEM Rear Tire
    ....The Wife said "You must have softer Roads or something". I was very carefull and only got 14,000
    miles from my OEM. At 12,000 miles in was not good in the Rain.
    ENJOY YOUR LIFE WITH A SPYDER
    PA
    Can’t help on the harbor freight question but wow…….I think that’s the highest I’ve ever heard of on Kendra’s. Mine was gone at 7200! Must have had a good tire! You almost got 3 times my mileage.
    Jul 2017
    Long Island NY
    Default 2017 F3-L Rear Tire Change - what's the axle hole dia?
    Thanks,
    J
    Feb 2020
    CT and ME
    I thought the same thing. Bought the Harbor Freight tire changer. DO NOT DO IT!!! Wicked pain in the butt to use and you will scratch up your rim. Remove the wheel yourself and bring it to a tire shop. Town Fair Tire did mine no charge as I bought the tires from them.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Aug 2019
    Stoughton, WI
    Axle is approx. .92 inches as measured by my calipers.
    2022 RT Sea To Sky
    INDIANA, USA
    Quote Originally Posted by JasonH View Post
    Thanks,
    J
    That is the way my rear tire looked like at 14000 miles.
    Really can't believe you rode 5000 miles more.
    Oh well, Ryde Safe. .....
    Feb 2022
    New Zealand
    I have a similar changing frame. Thinking I may get a bloke to turn up a spacer I can drop over the post so it fits the id rim size and the post size. Make sense??. I will have a measure next time I have the rim off.
    Nov 2018
    Waynesboro, PA
    Duplicate threads merged together here.
    My Spyder
    2012 RTL , Brown
