Results 1 to 8 of 8
    Nov 2018
    Claremore, Ok.
    Default trying to replace brake pads..
    I can't get the bolts out that hold the fender on so that I can see what I need to do. The bolts for the calipers are frozen on also. What the hell, over!
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Quote Originally Posted by Revalden View Post
    I suggest applying some type of " rust buster " or penetrant like Liquid Wrench a few times over a period of days. use a cloth to prevent OVERSPRAY and also tap on the bolt head to spread the liquid ..... If you have a large soldering iron you can also heat the bolt heads .... Annnnnnnnnnnnnd use a breaker-bar .....good luck .... Mike
    Nov 2018
    Claremore, Ok.
    Default trying to replace brake pads... what's the trick to removing the bolts?
    What's the trick to remove the bolts for the fenders and the calipers. Are they reverse threads, loctited in? I can't get them loose. Please help, I don't want to hafta take it to the dealer.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    Check this out. It may help. https://youtu.be/VbfFLIQ_PsU
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
    NO - not reverse threaded ( lefty loosey- righty tighty ) .... Did you read what I said about BRP's use of Lok-Tite ????? .... Mike
    Nov 2018
    Claremore, Ok.
    Thanks, I remembered the wrong video. I've got it now, thanks a lot.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Jan 2021
    Descanso, CA
    Exclamation Don't screw up the rear brake piston
    In many cases the rear brake pads wear out before the front pads. In which case buy the BajaRon tool to retract the piston. Don't screw this up or you will be buying a new caliper as the threads are easy to damage.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Northern Kalifornia
    Acetone and ATF fluid, half and half, is a good penetration mix.
