Results 1 to 13 of 13
    Dec 2020
    Hartwell, Ga
    Default Trailer tongue looks low
    Just wondering if anyone has done anything to raise the trailer tongue just a couple of inches so it will set more level on the Spyder.
    They make a 1-7/8 ball with a 2" rise but it has a 1" shaft. There's nothing with the 3/4" that I can find.
    Has anyone maybe drilled out the hole in the hitch to accommodate the 1" shaft? Any disadvantages?
    No more weight than it will be pulling I think it should work.
    Pro's and con's of doing so?
    Mar 2015
    Brockport, NY
    What type of trailer do you have? I ask because my 622 sits pretty level with the factory Brp hitch with no modifications.
    2014 RT-S Pearl White
    Dec 2020
    Hartwell, Ga
    I have the 622 trailer but I also have a 2020 RT Limited.
    Also it could be just me. I was mistaken once before....lol.
    Sep 2014
    USA
    try raising your air bag??
    Mar 2015
    Brockport, NY
    The curved tongue is also deceiving on the 622.
    Un less your TONGUE is at a 45 degree angle ...it will be fine .... Mike
    Northern Kalifornia
    You should be good just as you are. My father-in-law built custom trailers. He told me the tongue should always be level or a bit lower, never above level. Adjust your tongue height to your loaded trailer. Safety first always.
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Check out this link to a 2" hitch ball spacer for the receiver on your Spyder. This will raise the front of your trailer 2".
    https://www.canamspyderaccessories.c...acer-2-inches/
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Dec 2020
    Hartwell, Ga
    I'll post a pic later today to show what I'm talking about.
    Honestly, I may be looking at the tongue more than I am the trailer itself.
    Partzman, something like that is what I was looking for but with shipping it is a little over $40.00, the raised ball I was looking at is only $24.00 shipping included.
    Dec 2020
    Hartwell, Ga
    My TONGUE has been known to change position as needed.
    I was speaking of the trailer tongue. lol
    Dec 2020
    Hartwell, Ga
    Raising the air bag has nothing to do with the hitch ball height, it will only raise the body of the bike. The hitch is mounted to the axle frame/swing arm and does not move with the body.
    Besides I have 55 psi in the air bag.
    Dec 2020
    Hartwell, Ga
    After going out and looking again on level ground I guess I'm more concerned about the front of the trailer being so low to the ground. The trailer tongue does look quite level.
    I also took some pics. Honestly in the pics it does not look that bad, other than all the junk in the background.
    Maybe my old eyes are just messing with me.
    I guess we can move along to the next issue which is, I need new seals for the doors on the trailer. I washed it and found water inside, both the front and rear seals need replacing. Any suggestions on where they might be found aftermarket? D seals at the parts store maybe?
    Dec 2020
    Hartwell, Ga
    Never mind, I see that some of the vendors has the seals. Problem solved.
