Results 1 to 25 of 33
    Jun 2015
    Ritzville, Wa
    Default Does this tire look bad
    Does this tire look like it needs to be replaced?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Northern Kalifornia
    What would you do if a tire looking like that was on your family car? Would you replace it?
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Deffo a new tyre, ask Mike, Vredesteins are the way to go....
    But this one is shot
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Yup! What they sez!
    That one's well past legal in Oz, and well on it's way to being a gold plated invitation to hydroplaning hell!
    Yup! What they sez!
    .... and let me add, your tire is VERY close to having the Cord show ..... annnnnnnnnnnnnnnnnnnnd it might actually Blow out .... ie. - catastrophic tire failure ..... Mike
    INDIANA, USA
    Default How Many Miles?
    Quote Originally Posted by gkamer View Post
    Did you get your miles? Kendas go about 7,000 to maybe 10,000 miles. I got just about 10,000 miles on my OEM Kendas. Very sad but true 9,987 miles. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I gkamer
    Yes you need another tire, and this one was over-inflated
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Clinton, MS
    Quote Originally Posted by FlyBoy2121 View Post
    I gkamer
    FlyBoy2121
    FlyBoy, I disagree. I would call this the classic kenda normal everyday wear pattern for rear tireitess.
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    It's in need of replacement. Looks like it had too much air in it to wear in the middle like that.
    2021 RT Base - Petrol Blue
    Bulls-eye! I changed my Krapendas long before they got that bad until I went to the dark, but better side, tire world.
    Aug 2019
    Stoughton, WI
    Your tire is ...
    2022 RT Sea To Sky
    May 2020
    Troop,. I had to think about your piccy.... LOL.... Toast ain't my native language, I speak dutch here.... but after i grasped it, I found it funny as hell
    Swaybar (Ron's)
    Aug 2017
    New York
    I also think you might have too much air in the tire, that is why the center threads are gone and the side threads are still good. I watch my tires for wear and keep adjusting the tire pressure. IMHO.
    Quote Originally Posted by spyderwing57 View Post
    That was a common thought ( air pressure ) way back a decade or so ago ..... However, it has been de-bunked ( the theory ) because the rear Kenda has been tested from 5 psi lower to 5 psi higher and the wear rate doesn't change .... Peter and I examined this theory and decided the real issue is the WEAK tire construction that allows that tire to BALLOON at speeds above about 35 mph. ... Also the tire is wide which compounds the issue ...... Mike
    Sep 2020
    Middletown, NJ
    Exactly why I threw the Kendas in the trash at 3000 miles.
    2020 RT base , Chalk White
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    GONE,GONE,GONE!! Good that you asked the people in the know.
    T.P.
    Northern Kalifornia
    JMHO but I think BRP is out on a limb here. Spyders seem to be the go-to ride for all categories of riders for many reasons, from the experienced to the first timers. Installing a well documented defective item on a unit and turning it out to the public seems to carry a giant liability. In what other industry would a newcomer be expected to safety check a new purchase for a defective item in say 7k miles, after laying out nearly 30k for the purchase. Those of you who are seasoned owners know of these things, but unlike the first poster here he was just lucky that he found the defect before a serious issue came into play. It's so maddening to know that BRP is so purposely penny pinching and careless as to turn out a product to the public that could produce a catastrophic failure in such a short amount of ownership time. Many thanks to the knowledgeable posters on this site who have brought light to this issue and made new owners aware of a pending problem that needs constant attention. The problem is also exacerbated by an over PSI recommendation.
    Aug 2018
    Canada
    I Guys !!!
    When I bought my Spyder RTL from a private individual, it was 9000 kilos, and the rear tire was identical to the photo, and was overinflated by how much I unfortunately do not remember.
    FlyBoy2121
    Feb 2020
    N. Wilkesboro, NC
    I'd say you're good for another 30-40k miles. Just make sure you ONLY ride on the edges of the tire. No sense wasting perfectly good sides. If you're fat enough and can lean far enough over, I think you can do it. I've got confidence in ya! You can do it!
    2021 Honda HRV
    2245 Constitution class starship (refitted 2270-2271) (for sale)
    2021 Can Am Spyder RT (gone)
    2019 Honda CR-V (gone)
    2018 Can Am Spyder RT Limited (gone)
    2014 Kawasaki Nomad (gone)
    I Guys !!!
    FlyBoy2121
    That might be so FlyBoy, but all the OE Spec Kendas on Spyders wear that way, at least to some extent, even those that have been meticulously run at the 'correct' pressure shown on the Tire Placard - and also those that have been deliberately run at much lower pressures in an attempt to stop that sort of wear.... but failed!! .
    For any OTHER make of tire, then Yes, that wear pattern would indicate over-inflation, but that's not necessarily the case on the Spyder's OE Spec Kendas & their clones!
    I keep my rear tires inflated at 26#. They give me longer mileage that way. I average 15K with the rear Krapenda's. But who am I anyway.
    Aug 2018
    Canada
    The the Krapenda's: is a new kind of tire ???
    FlyBoy2121
    FlyBoy2121
    A site nickname for the OEM "Kenda."
    Aug 2018
    Canada
    I ARtraveler
    I understood everything, I have kenda Kanine on my Spyder RTL
    FlyBoy2121
    I ARtraveler
    FlyBoy2121
    Me too on the 2019
