Problem with key seat release not working, any ideas?
Hi, I am having trouble removing the riders seat. I push the key in & turn it clockwise but it does not release the seat. Turning it the opposite direction easily allows the front cover to open. Does anyone know how to remove the seat when the latch is not working? Really appreciate your help. Thanks.
Reason: Removed Prefix - this is a 'What should I do?' question not a 'How To: DIY' guide. ;-)
Push down hard on your seat as you turn the key. That may release enough tension that the catch will pop. If that doesn't work try pulling the ear of the seat out on the right side. You can see the latch and reach in with a screw driver or pliers and pull the latch.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I had my passenger seat off on Friday to wire my Shad sadddlebag lights. I had a challenger getting the seat off. It appeared that the key lock would not turn far enough to disengage the seat release. I remove the rubber plug when the cowl was off and could see the seat leash, but unsure if that would access the release. Like Pegasus advised, I ended up putting pressure on the cowl, and the seat came off. I suppose I could adjust the pin, but easier to put some pressure on the seat.
Rick
2019 F3 base
Shad saddlebags with Admore led light kit
BajaRon swaybar
Hopnel mini bra
BRP driver's backrest
Madstad windshield
Ultimate floorboards
CanAm Spyder accessories rear shelf with LinQ adapter
+ 1 on lubing the latch, it needs it. The frunk latch needs it as well. Ignore the lubing of these latches and its when not if you get some problems. Takes almost no time at all.
I had trouble with opening my seat several years ago. Once I opened it, I removed the locking pin, no problems with opening.
Originally Posted by Isopedella
...... Ignore the lubing of these latches and its when not if you get some problems. ......
I simply pulled the dipstick and used a drop of oil from it to lube the sticky seat latch while I was fueling up. Please explain to me a little more why I should not lube the latch mechanism under the seat? Thanks.
Reason: Fixed quote display
Your asking for something that is not in the sentence.
Try reading the whole sentence.
I guess my Maori to Northern Kalifornia lingo is struggling.
Hows this?
or
Mena ka warewarehia e koe nga reiti karekau e mahi tika ina hiahia koe kia tukuna.
or
If you ignore the latches sooner or later they will not operate correctly when you wish it to release.
Try reading the whole sentence.e.
To be fair, I had to read that whole sentence a couple of times before I understood it, Isopedella. The lack of punctuation makes it easy to misinterpret it, so I wouldn’t be too hard on 2dogs.
Pete
Reason: Fixed quote/s display
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Folks who have " removed the locking PIN " discovered that the seat can then move forward, and the seat edge will rub some paint off .... good luck .... Mike
Thanks Pegasus, feels like the seat is welded on. Mine is a 2018 F3 Ltd.
Cannot get under the seat at all to see the latch. Is the latch on the right hand side of the seat, front, middle or back?
This may help.
https://www.youtube.com/watch?v=LtUDlTER1jc
My 2017F3 is at the back of the seat in the middle.
Nice video and very well narrated. For me only, it's a little overkill. I just attached two very strong nylon strings to the latches and ran them both under the tupperware to an easily accessible location where I only know that they are there. They've been on there for several years and I test them periodically to make sure they still function as intended. As a very kind man named Peter told me once, the reason you down there and me (we) up here have trouble communicating is because we're both upsidedown. And yes, lubrication is very important, unless you're standing on ice.
Finally got it off. Have now greased it & added a secondary lead to pull the release. Thanks all for your help
Good work. All for sake of some lube. haha.
Thinking I will set up a pull type release myself. I have some 80lb plastic coated steel fishing trace and some crimps I may fab up and see how it goes.
Excellent idea!
