Results 1 to 13 of 13
    Member kdrewitt's Avatar
    Jul 2021
    South Carolina
    Default Trying to locate a fuel door for '21 RTL - anyone help?
    Hi, Need help trying to find a locking fuel door to install on my 21 RTL. I've searched the DIY forum and clicked on just about all of the linking trying to find a locking fuel door. The eBay and Amazon links are either "currently unavailable" or the link is no longer valid for the intended item. I've ordered one via Amazon and it was too big. I'm looking for a door that's 6 inches or less (outside diameter) (top to bottom). The doors I've seen on Amazon are either 6-1/2 inches or larger. Any help would be greatly appreciated. Thanks.
    indpls in
    just raise the seat
    Linden, CA
    Quote Originally Posted by kdrewitt View Post
    Hi... I see you are new to the forum. I can help with the fuel door give me a call 209-887-3283 9:00AM to 8:00PM Pacific Time, I am in California
    I will be glad to assist you
    Jul 2021
    South Carolina
    Quote Originally Posted by fatboy View Post
    just raise the seat
    There’s always one in the group…
    indpls in
    that is why its a two piece seat
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    It's difficult and messy to fill or top-up the tank from a fuel can with the seat raised. While a fuel door would be a nice solution, it seems that it may compromise the seat comfort. Eliminating the gas strut that limits the upward travel of the seat and using a link to prop the seat up in a higher position would improve fuel tank access and make it easier to access the rear suspension Schrader valve. One of these days...
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Quote Originally Posted by ButterSmooth View Post
    I put a gas door my 14 RT about 60,000mi. ago .... The only time I notice it ...is when I use it. Did you have one on your seat and then re-moved it ????? .... Mike
    I just dealt with this topic with " Spyderweber3 " .... if you want I can send you all the PM's I had with Him ..... I used to buy & install them as a Vendor ..... Mike
    Sep 2020
    Central Oregon
    i put a gas door om 14 RT about 60,000mi. ago .... The only time I notice it ...is when I use it. Did you have one on your seat and then re-moved it ????? .... Mike
    I've never seen one that fits a 2020RT. I just know that my leg rides on the portion of the front seat that is directly over the fuel cap.
    Spyder Tryke Pylot
    Harrington, Australia
    It’s a fair comment though, kdrewitt. Access to your fuel cap is protected by the lockable seat. Are you asking for a fuel door that you can insert into the side of your seat?……..because you don’t mention that in your question, which is why some confusion may arise.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    I found a record of the fuel door that I ordered it for my 2016 RT. I bought it on eBay from vendor. streetrend
    Description in listing:
    For 88-00 Chevy/GMC CIO CK Truck/Suv Matte Aluminum Fuel Gas Door Cover w/Lock
    This one has a lock, but I don't use it and it stays closed with out locking it.
    2022 Spyder RT Limited Sea to Sky Mystery Blue
    Jul 2021
    South Carolina
    thanks George, hopefully I can find it on eBay. I appreciate your time and effort!!
    Nov 2018
    Claremore, Ok.
    I'd like your PMs on this subject also, if you don't mind. Thanks
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
