Mixing Oil in RT
I have always used BRP oil when doing regular maintenance on my Spyders. Someone said that Castrol makes a synthetic blend that is the same as Can Am oil. I already have a gallon of BRP oil for my next oil change but thought about mixing a quart of Castrol with the CanAm oil. Would that be the wrong thing to do? Should I stay with 5 quarts of the same oil? I appreciate anyone's thoughts about this. Thanks!
Terry
2022 RT Sea To Sky
I agree some what, but boy this one will be big, I think!!!
As long as with in spec’s should be fine, please double check before getting too far. If not suitable for wet clutch is the biggest concern.
SpyderLovers Sponsor
Same specs. No problem. It is my understanding that BRP oil is just Castrol in a different bottle. Same with Ford, Chevy, Harley, Honda, etc. The only thing BRP about their oil is the container that you throw away.
SpyderLovers Ambassador
Same Oil?
...I can't see any wrong with this. But if you have a problem with the mixing of your oils, buy the needed amount and then you will be happy.
Same oil but a different brand is not a real problem.
Next Chapter please.........
ENJOY YOUR LIFE WITH A SPYDER
The only Castrol 5w-40 I see is Full Synthetic Castrol EDGE Euro Car formula. Is this what your talking about? The Can-am says its a synthetic blend. Does that matter?
I am not a fan of 'Blended' oils. My go to analogy is, take 90% tap water and add 10% crystal clean spring water. What do you have? That's what you're getting with a 'Blended' oil. If you're going to go with a high quality lubricant. What not spend a bit more and get 100% of the good stuff? Just my perspective.
The send thing you really need to know. If it isn't JASO MA2 rated, you don't want to use it in a Spyder. BRP recommends a 5w-40 blended oil because that is what they sell. When they sold 10w-40, that's what they recommended. Because Spyders rarely see cold start temperatures below zero Fahrenheit, a 10w-40 is a better viscosity for the Spyder. The further the spread between the low and high number. The less stable (more prone to breaking down) the oil is. In temps typically in 3 digit territory. Many customers are using 20w-50 in their Spyder with good results.
One good example of selling what you have instead of what is best for the application is BRP's recommendation that the Ryker use a wet clutch oil. Wet clutch oils are a compromise product. The engine wants as slippery a lubrication as it can get. Not only will it last longer, but it will get better fuel mileage. In a wet clutch environment, the transmission needs a lubricant that can stand up to gear crushing forces (something the engine only application never sees), and the wet clutch needs a fair amount of friction to work reliably. Exactly the opposite of what the engine and transmission needs.
Compromise products always have 2 things in common. 1- They, by necessity, are not as good at any one aspect as a single need product. And 2- They are more expensive. Using an automotive lubricant in the Ryker is not only less expensive. It will give you better service as you're only targeting 1 parameter. Which is engine lubrication.
Yes, a wet clutch lubricant will work just fine in a non-wet clutch application like the Ryker. You'll have no issues. It's just not the best option, nor is it the least expensive.
https://www.amazon.com/Castrol-Power...NsaWNrPXRydWU=
Also, their is no API (American Petroleum Institute) standard on the contents of partial synthetics or synthetic blends. Oil MFR's are not required to disclose that. You may be getting 95% petroleum/5% synthetic. API standards make it necessary for their products to be able to be mixed.
2022 RT Sea To Sky
From what I have read, Fully Synthetic is a marketing term which may well be blended with mineral oil in some unstated proportion.
I also have read, that therm to be looking for is 100% synthetic, which I'm led to believe is 100% synthetic oil and 100% synthetic additives.
Of course, who knows if what you read is actually true, but this was just my understanding.
Can Am Syder RT Limited (2021)
Triumph Bonneville T120 (2018)
