Which LED headlight kit? Lamonster or Slingmod
Currently trading my 2014 RT Limited for a 2015 F3 S. I am wanting to convert the headlights to LED. I was wondering what kit folks had the most success with or if there is one that is preferred. I do plan on having the dealership do the conversion. I watched the video and there are just too many parts to take off and put back on. Plus I dont have the various tools needed.
Any input would be appreciated.
I had a 2020 F3 basic, I used the LaMonster lights, very easy plug and play! No splicing, great brite LED lights. I did both head lights and fog lights! Just my suggestion!
2021 Spyder RT-L - Asphalt Grey
• Vredestein tires all around
• Rolo Laser Alignment
• Lamonster tire balancing rings/front
• Lamonster Sway Bar
• Lamonster belt tensioner
• K and N air filter
• Rear cowl - in place when you remove rear box
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
I have the Lamonster LED headlights. Very easy install. I installed them myself.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
Yes, like JKMspyder, I installed both headlights and fog lights myself! Saved some money and learned more about working on my Spyder.
Lamonster here all the way!!!
I had really good luck with the LED headlights from SlingMod, TricLED.com is the website. Really easy to install, did not require any cutting or modification. They are really bright!
I bought Lamonsters because they were half the watts and had no motor which can fail?
Sea Doo GTI-SE 90 Jet Ski!!
thanks everyone. much appreciated.
