Results 1 to 20 of 20
    Jul 2017
    Woodbine, Iowa
    Default Removing brake reservoir when accessing oil filter on 2021
    I am not ready to do an oil change yet but i did have the plastic off thre right side. I just tried to remove the brake reservoir so to access the oil filter. It did not want to raise off the bracket. I didn't want to pull hard on it, because I didn't want to break something. Does it lift up or pull out?
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Quote Originally Posted by gerald37 View Post
    I have a 14 RT , but it has the same engine as yours ...... I don't go anywhere near the BRAKE reservoir .... Are you sure you are in the right area ????? ................Mike .... I went over to cheapcycleparts.com and looked at the Fiche' for the oil, filter , & reservoir..... This looks EXACTLY like mine .... the OIL filter etc. is on the right side under the mirror.... that very large panel and smaller insulation cover must be re-moved to access the filter .... there are vid's of how to do an oil change on the 1330 engine .... Mike .....
    Apr 2019
    Clinton, MS
    Look behind the reservoir and you will see a small plastic tube. Take some needle nose pliers and pull it out. It serves to lock the reservoir to the bracket. I like to cut a piece of 1/4" tubing that is a few inches longer, cut the end slightly pointed, that way the next time you can just pull directly on the tubing to remove it. The slightly pointed end makes it easier to get back into place.
    Mike, on the 2020 + RT's its right in front of the oil filter.
    BTW, once you do it one time its a cake walk.
    Ed .... the OP has a .... 2019 RT Ltd. ..... Mike
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    True Mike, but he asked about a 2021 in his subject line. And the reservoir has to be moved to access the oil filter on that year spyder.
    GLIDE-ON>>>>>>>>>>>>>>
    "Blue Belle" 2021 RTL Chrome in Petrol Blue
    2021 RTL Chrome , Petrol Blue
    Sep 2017
    Durham,Maine
    Another piece of fine engineering. Trying to stuff 10lbs in a 5lb bag.
    2012 RTL , Pearl
    Aug 2020
    Georgia
    Quote Originally Posted by Gerald37
    Mine has a small amount of up and down play (the reservoir does) so I find that moving the reservoir up and down slightly will aid in removal of that pin/tube. Some surgical hemostat pliers will make sure you don't drop the pin/tube.
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
    Jul 2017
    Woodbine, Iowa
    I have a new 2021. I no longer have a 2019.
    2021 RT Limited
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Apr 2015
    Lodi WI
    Removing the little tube was a PITA. It's barley visible. I can see ZERO reason to put it back in as the reservoir hangs nice and snug without it
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by WilcoJunoHotel View Post
    The hemostat pliers work great, that's what I used also.
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Dennis in Lodi View Post
    I agree with this post. I left mine out but kept it just in case. I will keep a check on it until I'm satisfied that it will stay put without it.
    Well we now KNOW ....because you just changed what was listed at the bottom of your original thread ...... Mike
    Apr 2019
    Clinton, MS
    Next time you are at Home Depot or Lowes but 1 ft of 1/4 tubing. Cut in half using a slight angle cut "/". Makes it easy to pull out and easy to go back in, no worries about the reservoir bouncing loose.
    Nov 2016
    Upstate NY
    I was able to change my filter without removing the brake reservoir. I had no choice because I couldnt figure out how to move it, even after watching videos.
    2021 Sea to Sky RT , Highland green
    Nov 2016
    Upstate NY
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Are you able to change the Thread Title once its been submitted?
    This one reads
    Go to first new post Removing brake reservoir when accessing oil filter on 2021
    Started by gerald37, Yesterday 01:45 PM
    Last Post: Today 05:41 AM
    by Joel The Biker Go to last post
    Forum:
    RT Shop Talk
    Jun 2016
    indpls in
    the post is fine if you would read them all
    Dec 2020
    Hartwell, Ga
    It is a little hard to see if you aren't sure what you're looking for. It's kinda hard to get too also but, it's behind the reservoir towards the top and right up against it. It looks like a black piece of round metal or something.
    Sep 2020
    Middletown, NJ
    I found un-plugging the front connector, the reservoir can be moved to the back for lots of clearance to the filter. Just need to be gentle with the tubing.
    2020 RT base , Chalk White
    Mar 2019
    Ruidoso Downs, New Mexico
    That's what I'm trying to do but not for filter clearance but rather to aid in getting to the connections on the master cylinder. I'll try to find the 'tubing' that holds the dang thing in place.
    Off the subject but it looks like somehow you missed North Dakota! You should come out to NM and ride the western states with me; I'm not going east but need the same western ones you do plus NV!
    2020 F3L; gone but not forgotten are all the good miles!
