Removing brake reservoir when accessing oil filter on 2021
I am not ready to do an oil change yet but i did have the plastic off thre right side. I just tried to remove the brake reservoir so to access the oil filter. It did not want to raise off the bracket. I didn't want to pull hard on it, because I didn't want to break something. Does it lift up or pull out?
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
Look behind the reservoir and you will see a small plastic tube. Take some needle nose pliers and pull it out. It serves to lock the reservoir to the bracket. I like to cut a piece of 1/4" tubing that is a few inches longer, cut the end slightly pointed, that way the next time you can just pull directly on the tubing to remove it. The slightly pointed end makes it easier to get back into place.
Mike, on the 2020 + RT's its right in front of the oil filter.
BTW, once you do it one time its a cake walk.
Ed .... the OP has a .... 2019 RT Ltd. ..... Mike
True Mike, but he asked about a 2021 in his subject line. And the reservoir has to be moved to access the oil filter on that year spyder.
GLIDE-ON>>>>>>>>>>>>>>
Another piece of fine engineering. Trying to stuff 10lbs in a 5lb bag.
Reason: Tring = trying ;-)
Mine has a small amount of up and down play (the reservoir does) so I find that moving the reservoir up and down slightly will aid in removal of that pin/tube. Some surgical hemostat pliers will make sure you don't drop the pin/tube.
Sold: 2020RT base with numerous improvements and farkles
Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
I have a new 2021. I no longer have a 2019.
Asphalt Grey
Sena SMH-10
Garmin's GPS
Removing the little tube was a PITA. It's barley visible. I can see ZERO reason to put it back in as the reservoir hangs nice and snug without it
The hemostat pliers work great, that's what I used also.
I agree with this post. I left mine out but kept it just in case. I will keep a check on it until I'm satisfied that it will stay put without it.
Well we now KNOW ....because you just changed what was listed at the bottom of your original thread ...... Mike
Next time you are at Home Depot or Lowes but 1 ft of 1/4 tubing. Cut in half using a slight angle cut "/". Makes it easy to pull out and easy to go back in, no worries about the reservoir bouncing loose.
I was able to change my filter without removing the brake reservoir. I had no choice because I couldnt figure out how to move it, even after watching videos.
Are you able to change the Thread Title once its been submitted?
This one reads
Go to first new post Removing brake reservoir when accessing oil filter on 2021
Started by gerald37, Yesterday 01:45 PM
Last Post: Today 05:41 AM
by Joel The Biker Go to last post
Forum:
RT Shop Talk
the post is fine if you would read them all
It is a little hard to see if you aren't sure what you're looking for. It's kinda hard to get too also but, it's behind the reservoir towards the top and right up against it. It looks like a black piece of round metal or something.
I found un-plugging the front connector, the reservoir can be moved to the back for lots of clearance to the filter. Just need to be gentle with the tubing.
That's what I'm trying to do but not for filter clearance but rather to aid in getting to the connections on the master cylinder. I'll try to find the 'tubing' that holds the dang thing in place.
Off the subject but it looks like somehow you missed North Dakota! You should come out to NM and ride the western states with me; I'm not going east but need the same western ones you do plus NV!
2020 F3L; gone but not forgotten are all the good miles!
