Results 1 to 6 of 6
    Oct 2015
    Lynden, WA
    Thumbs up Anyone modified an a/mkt Driver Backrest for extended rearward travel? 2017 F3T
    I'm looking for a Driver Backrest 2017 F3T.
    OEM is not a consideration.
    I tried 2 different aftermarket Backrests from Amazon.
    Both pushed me too far forward. Hence my dilemma.
    Has anyone modified an aftermarket backrest for extend rearward travel?
    Thanks, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2020
    Prior Lake, MN.
    Haze, I have the Smooth Spyder backrest on my 2015 F3s, which is quite adjustable for rider or passenger. This is a spendy backrest, but very high quality and easy to adjust, I love how it works for me, and I am 6’2” tall. https://www.smoothspyder.com/f-3-bac...-luggage-rack/ You can also contact Jim at SmoothSpyder to discuss your needs. jim@smoothspyder.com
    Good Luck, Willie from Minnesota
    Quote Originally Posted by Haze View Post
    Thanks, David C.
    I've built backrests for a few different Spyders ..... I make the hardware parts and have always preferred using a " backrest " made by UTOPIA .... they are the thinnest, and most adjustable. .... I know your seat is different from the RT ... but a bracket could be sourced or built ..... back when they had the GS models, UTOPIA made backrests for them .... however they said you had to remove the seat cover to do it .... I was able to mount it without doing that ..... good luck .... Mike
    Feb 2020
    CT and ME
    I have the Lamonster driver's backrest for my F3. It has an adjustment screw for the backrest position. And it has a sturdy mounting bracket.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Active Member chunkmonk's Avatar
    May 2022
    west virginia
    Post
    Thanks, David C.
    If the main 'spine' piece is at an angle such that it just doesn't allow you to sit back far enough, it wouldn't take much to heat it while in a vise and just give it a bit of persuasion and you should be able to reduce the static angle by a few degrees which should translate into more 'sitback' for the rider. If you can, post a pic of the seatback you have and let's see if that wouldn't be possible...
    2021 F3 L , Stock Plugs (COILS, NOT WIRES!) Stock Brake Pedal Magma Red
    Oct 2015
    Lynden, WA
    Chunkmonk,
    Thanks for the suggestion.
    I should be able to try modifying a backrest bracket in a few weeks.
    Right now the bike is back together and needing a long ryde.
    David C
    2016 F3T
    Rear IPS Pack Rack
