Results 1 to 23 of 23
    Nov 2018
    N.E. Ohio
    Default Any Ryker air filter cross references besides K&N???
    Looking for a Purolator or Wix. Something I can pick up at local stores at a more reasonable price? TIA, cueman
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Good question, like to read a good answer on this one.
    Northern Kalifornia
    K&N is the least expensive filter you can purchase. The reason is that you can clean them, reoil them, and use them over and over and over. In case you weren't aware of that.
    Nov 2018
    N.E. Ohio
    Yes I know about KN but do not prefer them. Just want a good quality, name brand, throw away filter. Thanks, cueman
    May 2009
    Connecticut
    https://www.amazon.com/Can-Am-Spyder...0KIPSP8G&psc=1 Been using these in my Ryker (Both Filters) because I buy 2 for the price of one stock and I don't care for K&N. IMO
    Sea Doo GTI-SE 90 Jet Ski!!
    Nov 2018
    N.E. Ohio
    Hey thanks Sarge707! If I can’t find an over the counter locally, I’ll order two at a time and get free shipping. Good price!
    Jan 2009
    austria
    got a problem (!) in my display .. the dealer said "dirt in the air" ?!? but it just came one time ..
    they asked first if I use K&N - (have the original in) - look here
    https://www.youtube.com/watch?v=sJ3L-E-ufYo
    Active Member DickB's Avatar
    Jun 2021
    FL
    I called Wix support. They don't have one.
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by Sarge707 View Post
    Hey Sarge707, I just ordered two of the Ryker air filters with free shipping today. Thanks again, cueman
    Mar 2020
    Western New Mexico (Thoreau)
    Like cueman,
    I am not a fan of K&N! Anyone have a replacement filter for the Spyder RTL with Rotax 1330 engine? Video in this post gives high marks to Purolator and WIX. Any help would be appreciated.
    2021 Spyder RT-L - Asphalt Grey
    • Vredestein tires all around
    • Rolo Laser Alignment
    • Lamonster tire balancing rings/front
    • Lamonster Sway Bar
    • Lamonster belt tensioner
    • K and N air filter
    • Rear cowl - in place when you remove rear box
    Apr 2021
    North Carolina
    Quote Originally Posted by chris56 View Post
    Thanks for the info., never did buy the K&N hype. Nice to see I was right.
    Aug 2020
    Il
    Quote Originally Posted by Don60 View Post
    Like cueman,
    I have a WIX in mine. I believe its WL10238.
    21 Spyder base F3
    Mar 2020
    I’m sorry, did not specify! I’m looking for the air filter replacement, thanks
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Air and trans filters are same size on the Ryker.
    Change the trans twice as often
    I will second the recommendation from Sarge707...or maybe he seconded mine:
    https://www.spyderlovers.com/forums/...er#post1518099
    https://www.spyderlovers.com/forums/...er#post1530920
    Jul 2018
    Glasgow, KY
    Interesting tidbit, the factory filter from Doug's V85TT and my '22 Ryker are the same:
    So the Hiflofiltro HFA6101 will work perfectly.
    Sarah
    2022 Ryker Sport
    The Ryker has 2 air filters. Left side, engine. Right side, CVT cooling system. The engine air filter will usually last a long time. Not all that much air going through it. But the CVT side sucks A Lot of Air! And it does it all the time. This air cools the CVT belt. If this air flow is restricted. You can go through a belt in short order.
    We have seen a number of CVT side air filters clogged with grass, leaves, dirt, etc., and signs that the CVT belt life has been shortened. We recommend a K&N on the CVT belt side as it will flow more air dirty (to a point) than the paper filter flows brand new. Doing this can add a good deal of life to your CVT belt and overall drive system.
    Air flow through paper filters will drop quickly as they get dirty. If you run a paper filter on the CVT side of a Ryker. Check it often.
    Jul 2018
    Glasgow, KY
    Yes, I called up Paige and had a K&N for the CVT side in 2 days time. And you are exactly right, at 2500 miles the engine air filter and housing looked absolutely new, while the CVT filter looked like it had been on the bike more like 25,000 miles with all manner of dirt, bugs, grass, and leaf bits sucked in the housing. Hard to believe the difference. Thanks again for offering the K&N at the lowest price anywhere.
    Sarah
    2022 Ryker Sport
    Oct 2021
    Ontario
    Does the pre filter on the Rally help.
    Might be easier to check more often and clean.
    May 2020
    New Mexico
    We have been using the K&N filters in all of our shop Spyders and Ryker. Never an issue.
    I really like the guy in this video link. He is usually very accurate and through. But I have to say that this 'Test' is bogus. Yes, If you are going to dump clumps of very fine foreign material on your air filter, don't use a K&N. But this is not a real world situation. In the real world, fine particles are suspended in the air. This is a huge difference.
    The K&N filter does a great job of removing foreign material in a real world environment. The K&N will flow more air dirty than a paper filter does brand new. While this is probably not that important on the air intake side of the Ryker. It is a very good feature on the CVT cooling fan side. We've found several clogged paper filters on Ryker CVT filters. This can greatly shorten the life of the drive belt. It is a logical conclusion to assume that with much better airflow, even dirty, the K&N will extend the life of the CVT drive belt on a Ryker.
    I ran K&N filters on my dirt bike in the deserts and dunes of California with no problem. Many times riding behind several other riders creating a very fine dust cloud. I did have to clean it often. But this was better than having a clogged paper filter to throw away at the end of every riding day.
    Everyone has an opinion. And that's just fine with me. But I would suggest that you not base yours on the results of this particular video 'Test'.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by greer View Post
    Sarah
    I ordered 2 of them. Will post when I get them and installed to verify they work.
    David
    May 2020
    New Mexico
    It will work. From post 19 linke:
    Further air filter info-
    When I pulled the air filter, to remove a few bugs this morning, the following were printed on the factory air filter:
    UFI 30 138 00
    8104329
    004312
    Date code and made in Poland
    Research indicates this filter also fits the following:
    Genuine Aprilia/Guzzi Air Filter - AP8104329
    For Aprilia:
    '11-'15 Tuono V4 (all variants)
    '16-'19 Tuono V4 1100 (all variants)
    '11-'15 RSV4 (all models*)
    '04-'09 RSVR, Factory
    '06-'10 Tuono
    '06-'11 SXV and RXV 4.5/5.5
    For Moto Guzzi:
    '19-'20 V85 TT (all variants)
    California 1400 (Custom and Touring)
    Audace 1400
    MGX 21
    Eldorado 1400
    '12-'17 Stelvio
    Griso
    OEM Aprilia / Moto Guzzi part no. AP8104329
    Available from AF1racing.com (good source for Moto Guzzi parts) for $15.20
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by SportsterDoc View Post
    UFI 30 138 00
    8104329
    004312
    For Aprilia:
    '06-'10 Tuono
    For Moto Guzzi:
    Audace 1400
    MGX 21
    Eldorado 1400
    '12-'17 Stelvio
    Griso
    Ordered 2 from ebay which comes from Parts Giant. Both delivered for $27.78
    David
