Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Sep 2020
    Middletown, NJ
    I wrote it off as a learning experience. At the time I only had 15,000 miles of high speed trailing the 2-wheelers with 3.
    2020 RT base , Chalk White
  2. #27
    Mar 2022
    Huntsville, Alabama
    Quote Originally Posted by 907Guy View Post
    55, But not really sure I was doing 70 because I don't really look down at the sponometer when I'm in the curves and in the zone.
    Pay more attention to the road, revs and gears.
    Yeah I admit I was driving a little sporty!
    Formerly riding motorcycles, I'm a newbie and still very careful in the corners. I'm becoming more confident every day, so I was just curious.
    2012 Blue Spyder RT Limited
  3. #28
    Oct 2021
    Ontario
    " electronics " .... this would be the " VSS ", and what it would do ... it would Slow the bike down to a SAFE speed .... which would be to Prevent wobble .... IMHO I think the issue is " NEW driver " .... Spyders are not at all like mtc's. and they require a LIGHT touch. folks who "| guide " their spyders do much better than those that try to steer them ( at speed ) ...... Mike
    Our car has "yaw control". Growing up driving V8 pickups in a foot snow. The first time it kicked in it almost put me off the road.
    Not a fan. I can live with ABS, but the rest I can do without.
  4. #29
    Member 907Guy's Avatar
    Dec 2021
    Alaska
    I was most likely traveling too fast for the existing road conditions- highway 26 from Portland to the cost, and the wobble probably lasted realistically four or five seconds it just felt like an eternity, time really slows down in a situation like that.
    Don't think there's anything wrong with the spyder, just an overly aggressive rider use to riding high performance sport Turing bikes- BMW K1600 & 1250 RT.
    I think the front-end is light and just can't handle abrupt uneven road surfaces at high speeds; doesn't have enough suspension travel.
    I have a tendency to push beyond what reasonable riders would, just to test the waters; now I know!
    Tucson to Seattle, 2500+ miles in 9 days, Grand Canyon, Monument Valley, Bryce, Zion, Redwoods and up 101 around the Olympic Peninsula; I'm getting a feel for the bike.
    Next stop Alaska in May.
    Jay, Anchorage AK
    2021 RT Limited, Asphalt Gray Matallic/Chrome
  5. #30
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    Sorry about resurrecting an old thread but seeing as it was here I didn't want to create a new one. I had this happen to me the other day on the way home from work and was in a hurry.
    I was up on a narrow road that is used to service the cell and radio towers along the ridge of catoctin mountain so it is not taken care of that well with a very uneven surface at times
    I have a new set of shocks so I was probably going a lot faster than I should of been as the ride is a lot smoother now so I didn't realize how much faster I was going for that area.
    I was listening to some music and the next thing I know I have all 3 wheels in the air after launching from a hump in the road and come down and the handlebars just start violently going back and forth, I rolled off of the throttle didn't freak out with any brakes just trying to maintain a general direction on the road and let the VSS do its thing... luckily within a couple of hundred feet the wobbling stopped and was able to continue on normally after cleaning my pants out.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
  6. #31
    Feb 2012
    Spring City,Utah
    Truth be told, both tires were at 15psi cold this morning, at sea level because that's were I am. Two days ago when I checked them cold at 5500 ft they were 18psi. So maybe low pressure had something to do with what I experienced.
    If I missed the post where you said your tires were car tires I'm sorry. On stock tires 15# is too low. They should be up around 28-30#. Check your label under the seat or your owner's manual
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  7. #32
    Kenda tires .....REAR =28/30 psi .....FRONT tires = 15/20 ( according to folks here who use them ..... JMHO .... Mike
  8. #33
    Oct 2021
    Wichita, KS
    My dealer suggested I run my stock front Kendas at 15. I run them at 18.
    Peter Pan has struck again!
  9. #34
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by FrogmanDave View Post
    I run mine at 17 so we're close in our thinking. No problem and I like the "feel" of things much better.
  10. #35
    Aug 2018
    Piperton, TN
    I wonder if the VSS was freaking out
