Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 141
  1. #76
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    I use my kill switch unafraid all the time. What’s the harm? A switch is a switch right?
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Spyderco Paramilitary 2
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
  2. #77
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Woodenfish View Post
    Yes! Which is exactly the point being made regarding unnecessary failure points. If you've worked in the auto or electronics field, you understand why so many choose not to mess with known weak spots.
    2020 RT base , Chalk White
  3. #78
    Mar 2018
    mississippi
    I use it at the gas pump to keep the cluster powered so I can read the odo, reset the trip meters, and enter the miles into my fuel record while I'm pumping gas.
    I do as well so that I don't have to wait on the warning screen to pop up again.
    2015 Can Am Spyder RT Limited
    Magic Mirrors
    Short Antenna
    LaMonster Dual Power Plate
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
  4. #79
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Peacekeeper6 View Post
    Nothing like being stopped at a red light, taking a swig from the Lamonster drink holder mounted on the right handlebar, having the light turn green right away with a row of impatient cars behind you, and while hurrying to get going, accidentally hit the kill switch when putting your drink back to said drink holder.
    Good times, good times ....
    Happened to me more than once.
  5. #80
    Idaho
    Until it breaks! Then it's a credit card bender! The kill switch is an integral part of the right hand module. It it breaks you'll replace the entire module. Price probably won't break you, but it'll hurt!
    2014 Copper RTS
  6. #81
    Feb 2022
    Illinois
    Quote Originally Posted by RayBJ View Post
    I’m a retired professional auto technician with decades of experience but I don’t take that as knowledge on Can Am motorcycles. I have read many schematics and am an expert in electronics only on the line of vehicles I serviced at new car dealerships throughout my career at both foreign and domestic. If I were to see a schematic drawing I might have a differing opinion. Knowing that I don’t I made certain assumptions.
    I assume the wiring to the kill switch and ignition switch are all thin gauge low current carriers. When I hit the kill switch the engine ignition system circuit is broken. When I turn the ignition key switch a lot more current drawing devices is interrupted. My next assumption is that the ignition is on one relay while the other circuits I shut down with the key switch have their individual relays.
    My final assumption is that I ease the current draw interruption by hitting the kill switch first breaking a load and then use the key switch to finish the shutdown process. Therefore I don’t understand how hitting the kill switch is going to increase wear on a low current switch. If there was a prior failure rate with the kill switch at one point I am at the mercy of the BRP engineers to remedy the problem. At the end of the day you it’s a personal choice where in an ideal world makes no difference. I guess I just like to make the job of stealing the motorcycle a little more different. Haha!
    Garage Door Opener
    iPass
    DJI Action 2
    Noco Genius 1
    Noco GBX Booster X
  7. #82
    Idaho
    Woodenfish,
    You might want to get a service manual for your RT. Go to www.canammanuals.com. I think you'll surprised how some of your assumptions don't jibe with the real world!
    The kill switch takes one input of the Engine Control Module and takes it to ground to enable engine operation and breaks it so the input goes high to kill the engine.
    The ignition switch makes/breaks three circuits. One is a 15 amp circuit that feeds all the various running lights, except head lights and fog lights. The second is a 10 amp circuit that feeds power to some modules such as the DESS, and on/off signal power to other modules such as the ECM and VCM. The third circuit is an off position circuit that takes the power input to the modules down to ground.
    All of the heavy loads such as headlights are fed through relays directly from power fuses. The relays are activated by the ECM taking the coil negative sides to ground.
    Almost all electrical devices on the Spyder are controlled by making/breaking the ground side, not the power side.
    2014 Copper RTS
  8. #83
    Feb 2022
    Illinois
    So again, what is the problem in using the kill switch? By your description IdahoMtnSpder I’m not seeing it. I’m new to motorcycles, Spyders and this forum. Is there a well known manufactured gremlin lurking inside the kill switch ready to cause mayhem on my new $30K motorcycle that I need to know about?
    Garage Door Opener
    iPass
    DJI Action 2
    Noco Genius 1
    Noco GBX Booster X
  9. #84
    Dec 2013
    Woodenfish,
    And there have been a number of owners here on the Forum reporting (& lamenting ) failures in their Kill Switches! . Nothing else, just the Kill Switch - but that means it's a case of 'Spyder no go' until it's fixed, usually involving a bit of a wait while the dealer orders in a RH Control Module (usually one of those long & expensive waits.... ) & then eventually finds time to fit it & check everything works again!
    Basically, YES - this Kill Switch failure appears to be more of problem on Spyders than for most other motorcycles, but going by the threads posted here, it's mainly if you always use the Kill Switch to shut your Spyder down....
    Just Sayin'
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  10. #85
    Feb 2022
    Illinois
    Thanks Peter, I’ll add the kill switch to this growing list of dubious parts on my new purchase.
    Garage Door Opener
    iPass
    DJI Action 2
    Noco Genius 1
    Noco GBX Booster X
  11. #86
    Dec 2013
    There's no denying they are can provide Wonderful Ryding & be a real blast when they're working properly, with lotsa great concepts & devices included... it's just a shame that the execution of some of those concepts/devices & the quality of some of the inclusions hasn't quite been up to the standard that most expect from machines (or tires ) that cost as much as they do?!
    Definitely not gonna give it back or stop ryding, but it's a shame they just don't seem to listen....
  12. #87
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Last time I used the kill switch was on our local 42nd traverse.
    I crawled back and shut it down.
    Damit double up. Still getting the hang of this site.
  13. #88
    Active Member jerrydonna's Avatar
    Jun 2017
    Suffolk Va
    ok I found it......... Now I understand what it is... I thought it was like a ejector seat for the rear rider
    2012 , java
  14. #89
    Dec 2013
    Quote Originally Posted by Isopedella View Post
    Dam double up. Still getting the hang of this site.
    Fixed it for you!
  15. #90
    Jul 2010
    Las Vegas, NV
    I’ll put my MSF Safety Instructor hat on; use the engine cut off switch EVERY TIME you turn off the Spyder. This creates muscle memory. If you are about to crash, are on fire, going off the road……you are only going to do what you have trained to do. Do not remove your hand from the grip to turn off the vehicle! You are in a state of panic if one of those examples happen. We don’t think properly in a state of panic. If you have made it a habit to turn it off with the engine cut off switch, you will do just that, even if you are in a state of panic.
    Now to put on my Spyder Tech hat: I have never (in thousands of customers) seen an engine cut off switch failure. Ever. I have read about one or two on here in over 12 years, and my suspicion is that someone used a pressure washer or something on that switch and damaged it. Don’t do that.
    Use it like you are supposed to. Take a class, see what the professionals teach. Read the manual; see what the engineers and designers recommend.
    SpyderAnn had a Thermal incident. When it happened, she promptly got off the road, and used the engine cut off switch. She escaped unharmed. The Spyder was incinerated.
    Joe Meyer
  16. #91
    Feb 2022
    New Zealand
    I wondered where the kill switch turn off came from.
    Muscle memory you say, great if you are on fire, about to crash of about to run off the road.
    Really????.
    Reckon if I were about to crash, on fire, going off the road the last thing I would be thinking of was to turn the bike off.
  17. #92
    Jul 2010
    Las Vegas, NV
    Really. That’s where training comes in. Emergency procedures. Practice. Take the class. Learn. Practice more.
    I guess shutting your eyes, swearing, and hoping for the best is a technique; just not a good one!
    Joe Meyer
  18. #93
    Feb 2022
    New Zealand
    I guess our courses differ from yours .
    The kill switch is not discussed.
    Nor is if on fire, I will mention that on my next course.
    I agree with the comment of shutting your eyes, swearing, and hoping for the best is a technique.
    Along with of other counterproductive things.
    Some of the things discussed at my last course I attended.
    Lost or broken down.
    Stop signs.
    No passing lines.
    Safe following distances.
    Pressure and riding at your own pace.
    Cornering.
    Overtaking.
    Braking.
    MILO. mirrors indicate look move
    Scanning at lights and intersections
    Indicating
    Tiredness
    Hydration.
    I have completed a couple of courses. I have done our Bronze - Silver twice. Once with my son. And about a dozen Gold courses.
    Been legally riding since 1979 and ya know I learn something from every course.
  19. #94
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    The potential consequence of one poorly timed bump of that switch outweighs any dogmatic insistence on its use. I've considered using a drop of epoxy to disable it -- guess I can be overly dogmatic too. But, my decisions only effect me...
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
  20. #95
    Feb 2022
    New Zealand
    Ha. Reminds me of a situation I got into a few years back. Riding 2 up with the wife. 2009 Triumph America. Going downhill to a right hand sweeper. Just prior to tipping in for the corner I lost traction with both tyres. Something slippery on the road. Big wobble. Crikey! Its still upright. Great. Doing about 50mph now. Used my riding skills and a lot of luck I reckon to keep it upright with gentle steering left and right while sliding sideways and forwards. Kinda feathering the throttle now, hoping to pick up some traction. Trying to get a little forward momentum going and less of the sideways stuff. Now sliding in a curve with a small amount of forward motion. No real traction. There was a farm fence. A driveway. And a letterbox on a pole about 5m out from the fence. There was a drainage ditch along the road but a culvert where the driveway was. I was thinking this is really going to hurt, but hell im upright. I focused on the gap between the fence and the letterbox on the pole. Maybe I can do this. Give it a crack. Sliding towards the fence. A little more throttle. Forward curve type progress. Managed to get enough control to holeshot between the fence and the letterbox at about 30 or so. The wife bless her just sat still and quiet. Later on they said they saw us sliding and cut right and avoided that bit of road. I was the 2nd rider of about a dozen bikes. Awesome skills was mentioned when we stopped for a coffee ½ an hr later. Blokes shaking their heads. Hardly believing what they say. Awesome skills… and the like. I said I was lucky. Then I reflected on what had occurred and jumped on the phone and made a phone call about the substance on the road.
  21. #96
    Oct 2021
    Wichita, KS
    This thread has strayed a bunch.
    Peter Pan has struck again!
  22. #97
    Feb 2022
    New Zealand
    Yeah Nah not really
    Reflecting on the advice about you are on fire, about to crash of about to run off the road - hit the switch.
    If I did hit the switch when I thought I may crash, before I decided to attempt to ride it out.
    I would have crashed.
  23. #98
    Dec 2013
    I have completed a couple of courses. ..... and ya know I learn something from every course.
    Same thing with our courses here in Oz, Isopedella, those I've taken & also those I've helped develop &/or deliver - been like that since the early/mid 80's when EFI engines became the norm rather than the exception.
    As for how often these failures occur, a simple search here on 'Kill Switch' brings back 3 pages of results... on the first page alone, more than 8 of those are 'Kill Switch failures' that aren't purely operator error &/or someone toggling it as a gag. The Oz Forums I'm a regular reader of also report similar if not higher failure rates...
    Admittedly, people do tend to come to Forums like this to report &/or resolve any problems they may be having with their particular machine, so we might tend to see more of the problems reported than most will ever encounter, but even so, it's clear that amongst those that use them, Kill Switch Failures on modern motorcycles are not an isolated or even an all that infrequent event.
    Still, as with so many things, it's YOUR machine so it's YOUR choice what you do/how you shut it down; but personally, I choose not to get caught out, especially not somewhere remote or late at night, by anything as simple to avoid as an unnecessarily (over-)used Kill Switch failure ever again!
  24. #99
    Feb 2022
    New Zealand
    No longer a lone voice.
  25. #100
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Default Kill switch
    How many use the kill switch to shut the bike down?
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
