Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 141
  1. #51
    Feb 2020
    N. Wilkesboro, NC
    NOTE:it's even more fun to do it to strangers bikes while they are in the 7-11 or other store.
    I'd recommend NOT doing that to a strangers bike. I'd even go as far as to suggest nobody touches someone elses bike. Plenty of unhinged people out there who might get a bit testy.
  2. #52
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by MONK View Post
    And I'm one of them------ Don't touch my ryde!@!!!!
    2014 RTS , Circuit Yellow
  3. #53
    May 2018
    Salem Oregon
    when I was in the service the big deal was to reach over and flip your buddy's kill switch on the road. We were a fun bunch
  4. #54
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Lew L View Post
    Hope all is well with you and yours Ray, We are fine-- probably a ryde around Lake Tahoe tomorrow.
    All is good here, going for another short ride this weekend to Barkerville. A couple hundred clicks each way, nothing serious. We should be heading south this weekend to eventually meet at Norcal, but alas, we could not get across the boarder if the Rally was on.
    Hopefully next year we can get back to some kind of normal, it would be great to see you again.
    Have on your ryde.....
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
  5. #55
    Dec 2019
    Canada
    I’ll do this now! Thanks!
  6. #56
    Bossier LoUiSiAna
    Quote Originally Posted by ozarkryder View Post
    I took the MRF Basic Motorcycle Safety course. There they recommended to always use the kill switch to shut down a motorcycle. The reason was to build muscle memory in case of an emergency
    Was doing same well before my class & thankfully no problems. Honda,HD,Yamaha & well ingrained procedure now
  7. #57
    Feb 2017
    Quote Originally Posted by MNBK View Post
    In 45 years of riding and having been an MSF Instructor, I have always used the "kill switch". Immediately after I shut the engine off with it I turn the ignition off with the key and clip it to my belt. As Ozarkryder said it is muscle memory and just a normal habit for me.
    YMMV with what you do.
    Same circumstances here, although my MSF instructor days were rather long ago now. I agree that "muscle memory" and developing a normal habit can go a long way when a sudden panic situation rears its ugly head. I wonder how I know? Appears to have worked - and more than once over the years - because I'm still here, or at least was the last time I checked!
  8. #58
    Jun 2015
    Ritzville, Wa
    Default To kill or not to kill (switch), that is the question
    Is there any specific benefit to using the Kill switch after turning off your Spyder? Or is it just there basically as an emergency stop button…..
    Never mind, got my answer
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
  9. #59
    Feb 2019
    Portland, Oregon
    At the insistence and support of the battery makers, motorcycle mfrs install kill switches to sell more batteries to those who use the kill switch and walk away w/o turning off the igniton. Best policy; Turn of the ignition and immediately remove the key.
  10. #60
    Jan 2015
    southern WI
    Never use it, never will. Waste of space imho.
    2016 RTS , Pearl White
  11. #61
    Sep 2020
    Middletown, NJ
    Another legal team accessary. I never use it.
    2020 RT base , Chalk White
  12. #62
    Mar 2013
    Maumelle, AR
    I use mine all the time to turn off my Spyder. After I turn my key off, I flip it back on. But that's me.
    2020 RT Limited , Chalk
  13. #63
    Oct 2021
    Wichita, KS
    Quote Originally Posted by Mazo EMS2 View Post
    If your throttle ever sticks you may change your mind. Been there, done that! And approaching a curve at that.
    Peter Pan has struck again!
  14. #64
    Back in the (early?) days of carburetored engines, where carbies were rudimentary, often either gravity fed or served by a fuel pump that was mechanically driven by the engine turning over (even if just coasting 'in gear') & carburetors could easily flood/overflow &/or fuel lines could rupture & spray fuel over a hot engine, having a Kill-Switch was a great idea that contributed significantly to motorbike & rider safety.... but as the technology, carburetors, & fuel delivery systems improved, that contribution waned and gradually disappeared, especially following the introduction of modern fuel injection systems!
    Nowdays, once the ignition is cut there's no spark, no injector pulse, no fuel pump, no fuel flow, and all the (other?) electrical things that the kill switch was designed to cut instantly in the event of a failure or over-run in one of the other 'legs' of the ICE running cycle are being cut by the ignition anyway, so there's really no real need for an 'additional' switch to do exactly the same thing, but I believe they're still mandated... - just like on/off switches & separate switches for fuel pumps are mandated for (some?) light/ultra-light aircraft.... they're a hangover from the days when these things were useful & even played a part in keeping the machinery safe &/or saving lives, so they are still included just to satisfy the legal mandate, even if they aren't quite so useful or life-saving anymore!
  15. #65
    Jul 2021
    IL
    The best use of the "kill switch" is to flip it on a buddies bike when you stop to eat, gas up, etc. Then watch him go a bit crazy when the bike won't re-start. The only time I have ever used a kill switch myself is when I had a tipover of a regular motorcycle and it was the fastest way to shut off the engine since the ignition key was located on the side of the bike which was down on the ground.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
  16. #66
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Those switches were mandated around 1970±2. They were for emergency responders -- they standardized the way a motorcycle could be shut off in the case of an incident. From then on all bikes had a red switch on the right handlebar.
    In the early days they just cut off the sparks. Many, many bike batteries were cranked into oblivion when it was accidentally flipped off. I tend to not use mandated 'features'.
    It's a good adrenalin rush if you bump it passing or on the interstate!
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
  17. #67
    Clinton, MS
    Guess I'm just too set in my ways. Last thing flipped on before starter button. First thing flipped off when done. Hope its never needed but the muscle memory is there.
  18. #68
    INDIANA, USA
    Default Kill Switch?
    ...I have only used it for emergency reasons. I have heard that some people have had some issues.
    As others have said, it has been around for years....
    ENJOY YOUR LIFE WITH A SPYDER
  19. #69
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Little Blue View Post
    Just 1 more failure point to troubleshoot IMO.
  20. #70
    I use it at the gas pump to keep the cluster powered so I can read the odo, reset the trip meters, and enter the miles into my fuel record while I'm pumping gas.
  21. #71
    Feb 2012
    Spring City,Utah
    When I started riding there was no such thing and I have never bothered with it. Other than to mess with a buddy at a gas stop
    Last edited by Peter Aawen; 04-06-2022 at 10:14 PM. Reason: Otger thean = Other than ;-)
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  22. #72
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Nothing like being stopped at a red light, taking a swig from the Lamonster drink holder mounted on the right handlebar, having the light turn green right away with a row of impatient cars behind you, and while hurrying to get going, accidentally hit the kill switch when putting your drink back to said drink holder.
    Good times, good times ....
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  23. #73
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    The "key" word is SWITCH.
    This is a MECHANICAL device.
    All MECHANICAL device have a limited life expectancy of a certain amount of "cycles".
    Those cycles are designated in their design specs and AGE also play into that factor.
    So it is not a matter IF but WHEN it will ultimately FAIL.
    So you have a choice.
    1. Not to use and pretty much never worry
    2. Use it and EVENTUALLY find out.
    In 56 years on the road, I have never used that switch except ONCE when the bike went down and kept running.
    I have seen others that always use that switch. I'm still wondering if they ever got their bikes started or if they are still stranded!
    AJ
    Last edited by Peter Aawen; 04-06-2022 at 10:13 PM. Reason: EVENTUAL = EVENTUALLY ;-)
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  24. #74
    Sep 2015
    Chilliwack, BC. Canada
    When I started riding there was no such thing and I have never bothered with it. Otger thean to mess with a buddy at a gas stop
    Now you have me questioning myself....I’m now not 100% sure if my old ‘49 Royal Enfield had a switch or not.... i do know that it did not have a battery, so I’m thinking probably NO KILL SWITCH either. Damn memory lapses!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  25. #75
    Feb 2013
    Edinburg, TX
    I do that also, to let the music keep playing, and also to watch the fuel gauge rise... it tells me when to watch carefully for the splashback to stop pumping. (I don't engage the auto-shutoff in the pump handle.)
    As for the old battery-killing futile cranking, that doesn't apply to Spyders, since the starter won't even engage. Thanks to the computer technology!
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
