Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 141
    May 2011
    Alamo, Texas
    Wink Shutting off Spyder -- neutral or kill switch?
    For my RT with a SE5 transmission, the manual says to put it in neutral, set parking brake, and turn key off. The girl who sold me my bike and went through all the shut down steps said she always just hits the kill switch then sets the parking brake and turns key off. That's the easiest but does it hurt the engine to continually turn it off with the kill switch.
    Dec 2008
    Syracuse, NY
    I always use the kill switch. Just in case there is ever a problem while riding, and you need to hit the kill switch, it will be ingrained into you brain. I have an SM5.
    Aug 2010
    Casa Grande, AZ.
    I was told to use the kill switch. It is also the way I shut off my Yamaha and everything was OK.
    Mar 2009
    North Hampton, NH
    Quote Originally Posted by wyliec View Post
    The kill switch wouldn't be there if it wasn't to be used.
    It's a very good habit to get into to turn the engine off using the kill switch. Just remember to turn it to the "run" position when you go to start up the Spyder again!!!
    Jun 2010
    Las Vegas
    I use the kill switch.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    A bike mechanic friend tells me that from his perspective, all the kill switch adds is a other point of failure for the bike to leave you stranded somewhere. He sees nothing it adds that the key doesn't already handle. He says he's had to replace a number of them over the years.
    I agree with my friend and only use my kill switch when I hit it by accident.
    Apr 2009
    Oakhurst, California
    I use kill switch everytime, then parking brake and then turn key off.
    Feb 2009
    Ceresco, Michigan
    Always use kill switch. Anyone who rides much will tell you this-- been a well known preference for many years for most bikers.
    It's a safety reflex issue. If that is how you're programmed to shut the bike off--- that is what you'll do during and emergency should the need to shut her down arise. Never had one fail.
    The manual also recommends you practice doing and emergency shutdown while riding so you know what to expect.
    Invalid Emails
    Mar 2011
    NE TN
    Tks to all. Kill switch will become part of the shut down process.
    Invalid Emails
    Mar 2011
    NY
    I always do the kill. Personally, I recommend shifting into neutral before the kill, just in case you decide you want to move it around a little w/o bothering to start it up (easier to push in N). I often shift into N while approaching my destination, hit kill, coast up and hit the brakes.
    May 2011
    Cantonment, FL
    I always use the key to turn off the engine, I did it with my wing and I now do it with my I don't touch the kill switch
    Be Safe
    AC
    Invalid Emails
    Sep 2009
    west Texas
    Quote Originally Posted by MarkLawson View Post
    I agree with you and your friend. Living in a small farming and ranching community and having a motorcycle background, I wound up working on lots of friend's four-wheelers when they started becoming popular with farmers and ranchers. Most of the time the fix was as simple as putting gas in the tank, turning the gas petcock on, or cleaning an air filter. I replaced a few fouled plugs, a few batteries, and occasionally repaired some wiring that was destroyed by running through a mesquite or cedar bush. I also turned on a few kill switches that had been turned off and not turned back on but the only real part failure I ever found was two defective kill switches. I really think I can reach the key about as fast as the kill switch.
    Cotton
    Very Active Member SpyderLady's Avatar
    Sep 2009
    Moscow Mills, MO
    Quote Originally Posted by Firefly View Post
    I have ridden Harleys and now Spyders. Kill Switch should always be used as indicated by many.... safety first!!
    SpyderLady
    Gee... I had been just stuffing the tranny into neutral, setting the parking brake and turning the key off... Your logic behind using the kill switch is solid and I believe that I'm going to try and get used to adding it to the process. Thanks!
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Quote Originally Posted by RGVSpyderGirl View Post
    A close by Spyder Rider called me the other day saying his RS SE5 would not start and would I come over and check it out for him.
    I got on his Spyder switched on and realized Spyder was not in neutral so had to push brake to start....Safety lock out on SE5...
    Freebob...
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by bikeguy View Post
    Cotton
    On my spyder my thumb is right next to the kill switch. So, for me, the key would take a split second longer.
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    The operators manual states the following:
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Huligan kill switch = trigger. Personally, I use it every chance I get.
    Sent from my Xoom using Tapatalk
    Banged Up Member
    Dec 2009
    Sanford, Florida
    Stop, first gear (never in reverse even if headed down hill), parking break, ignition switch, kill switch. (Done mostly for theft purposes)
    Nov 2008
    las vegas, nv
    Stop, ignition off and parking brake set.
    I don't think about it. One of benefit of se5.
    6 states down 42 states to go
    Very Active Member ArmyJoe's Avatar
    Jul 2009
    Columbus, Ohio
    As use the kill switch as taught in the MSF course.
    Though every time I called it a "kill switch" I got yelled at.
    2009 Yellow SM5 with BRP R35 saddlebags, CHAD windshield, ESI Up & Out Mirror Extensions, ESI 4" Handlebar Risers, Hindle muffler, Green Filter, Juice Box Pro, Throttlemeister, Crampbuster, Cortech Sport Tailbag, trunk liner, trunk spring, 12V trunk outlet, Eastern Beaver PC8 Fuse Panel, and two dashboard Powerlet outlets.
    Certified Huligan
    The user formerly known as GIJoe
    Invalid Emails
    Sep 2009
    west Texas
    I expect that you are right. My logic in thinking that I could reach the key just as fast was in assuming that I would be off the bike when I needed to reach the ignition or kill switch. Just about all of my previous experience has been on 2-wheelers and most of that on dirt bikes. There has been many, many times when I needed to reach the kill switch and the bike and I were both on the ground. A few times on bikes on the street as well. I can think of only three occasions when I needed the kill switch or ignition key while still on the bike. All three involved stuck throttles.
    Even though I probably will continue to use the key to kill the RT, I stand corrected.
    Cotton
    Apr 2010
    Puget Sound, WA.
    Smile
    OK... Just my $.02...
    We use the kill switch. I try to go to neutral as much as possible before hand as well.
    Now that said... My brain is twisting here...
    I would MUCH rather have the kill switch go bad or wear out than the ignition switch.
    Please correct me if I am not fully informing this correctly...
    We had the rear Frunk lock fall in our hands the first time we locked it. Long story short... BRP told our dealer that we had to replace both keys, tumblers and main switch. As they do not sell just the tumblers. So we got new keys and such. Something about programing issues and such.
    And if I remember correctly the main switch is about $300 plus keys and programing of these keys. Oh and a new tumbler for the rear frunk and potentially the Trailer (As they give us a new one for it as well when new).
    Aaaaaaanyway. I see the kill switch as a cheaper option parts wise than the main switch . I am sure the labor would be potentially cheaper as well...
    Apr 2008
    pennsauken nj
    Default kill
    first gear,kill switch. (never use parking break) I remember many complaints of pedel getting stuck in lock position. Don't need that kind of trouble.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    Quote Originally Posted by IWN2RYD View Post
    Your assumption is that by using the kill switch you're NOT having to use the ignition switch. Obviously, you'll still use the ignition switch every time, regardless if you use the kill switch or not. By using the kill switch, you have introduced another potential point of failure into the equation, and one I believe is not necessary.
    I see no savings here.
