Results 1 to 15 of 15
    Nov 2018
    Tonopah, AZ
    Default Outer edge wear on right tire only
    I noticed this weekend that the right tire has a lot of wear on the outer edge only. The left tire is wearing normal.
    I do see there is no Castor or Camber adjustment on these machines. Dumb.
    What would be causing the right side only, bad shock??
    Stock tires, New tires ordered, Rear Kumho Ecsta AST KU25 225/50-15 And fronts, Hankook Ventus V4 ES H105 175/55-15
    Stock Suspension, I have a full set of M2s on the way.
    I did have the dealer redo the alignment about a week after I bought it in 2019.
    2018 F3 Limited, Purchased new March of 2019.
    2018 F3 Limited , Stock Doc Humphrys Intense Red
    I would say that it is time for a "laser" alignment.
    Northern Kalifornia
    the " Toe-in " is off on that side. .... it won't ever get better, without an alignment ..... Lazer is best ..... PS - most dealers don't use / have the Lazer equipment .... check the list of independents and Dealers who can .... good luck .... Mike
    Northern Kalifornia
    If it is difficult to find a laser alignment near you at least you can check your toe in on your own and adjust it if it is way out.
    Mar 2020
    Western New Mexico (Thoreau)
    QuadRAGIN, I just had mine checked at a dealer in Chandler, mine was fine and still had to pay the fee quoted, but peace of mind is worth a lot to me! Tech understands/was trained on the Rolo Lazer machine. I would check with them.
    2021 Spyder RT-L - Asphalt Grey
    • Vredestein tires all around
    • Rolo Laser Alignment
    • Lamonster tire balancing rings/front
    • Lamonster Sway Bar
    • Lamonster belt tensioner
    • K and N air filter
    • Rear cowl - in place when you remove rear box
    Nov 2018
    Tonopah, AZ
    Quote Originally Posted by Don60 View Post
    Ya it looks like most of the Ride Nows have the ROLO, Just not seeing how it would be off by like 1/4" in Camber just because the Toe is off. Ride Now Goodyear did the laser alignment the first time a week after I purchased it. I don't really trust Ride Now...
    I'm looking into buying the alignment system and then everyone will have a west side shop that can do them if they don't want to pay an arm and a leg.
    Last edited by Peter Aawen; 04-04-2022 at 09:56 PM. Reason: Fixed quote display & removed superfluos CR's ;-)
    Dec 2013
    Quote Originally Posted by QuadRAGIN View Post
    Do you have adjustable pre-load on the front shocks?
    Wind them (or that one... ) up to much and you'll be increasing the camber AND varying the Toe In/Out as the suspension's ride height increases!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2020
    That sounds good, good luck with your new adventure! Learning to use the alignment tools will help many in your area.
    Nov 2018
    Tonopah, AZ
    It’s the factory shocks and they do have adjustable preload on the springs I’ll run the adjuster up a bit and see what happens
    Thanks for the tip
    If have a " 1/4 " off for the Camber .... The Spyders front suspension has a FIXED camber in it's design. If it's OFF then something is damaged.... As others have said " Manual Adjusters " will change the Camber however not by much ...... your tire wear is an " alignment issue ".....good luck .... JMHO .... Mike
    Nov 2018
    Tonopah, AZ
    I have not found anywhere that say manual adjusters, Im going to jack her up and check everything over for damage or being loose
    2018 F3L Cat Delete, Two Bros Pipe, Doc Humphreys Belt Tensioner and Pedal Extender, 17" Freedom Windshield, Spyder Extras Sway Bar & End Links
    Read posts #8 and #10 ..... Mike
    Nov 2016
    Upstate NY
    Check the upper and lower ball joints for excessive wear
    2021 Sea to Sky RT , Highland green
    Nov 2018
    Tonopah, AZ
    Jacked up the front end, everything is tight.
    Using a large framing square I did notice the Camber changes alot just in turning the tires back and forth. Look like Cam-Am uses the same crappy front end geometry on Spyders that they use on their side by sides. I guess its a good thing these tires are like $300 a piece.. FYI Still no word back from the makers of the ROLO System. May be forced to have Dealer do the alignment
