Results 1 to 18 of 18
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    Default What does it take to Remove the Dealer Decals on my F3?
    I would rather not have the dealer decal on my F3. There are 4 of them and, no offense or disrespect to the dealer, but I don't want them on my bike.
    Do you have any experience in removing one of these decals? Can they just be pulled off? Is there sticky goo underneath that has to be removed? With what? Will pulling them off harm the finish/paint? Thanks for any help!
    Last edited by Peter Aawen; 04-02-2022 at 08:49 PM. Reason: Removed Prefix - this is a 'How do I?' not a 'How to:' DIY explanation....
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    INDIANA, USA
    Default Dealer Decals
    ...Four Decals, did they charge you for them?
    Or did you get a bigger discount on your Spyder?
    Anyhow be careful when you try and remove the decals.
    Sometimes they come off and some are a real pain.
    Slowly peel off and see what happens. I have used a very little rubbing alcohol to help.
    Good Luck on Your Mission. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Feb 2012
    Spring City,Utah
    Goo Gone will soften the glue and allow you to pull them off without any damage.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2022
    New Zealand
    Gentle heat from a heat gun maybe.
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Use a hair dryer to heat them up. Then pull gently.
    Alcohol will clean up what is left.
    2022 F3 Limited , Monolith Black / Dark
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by DriftersWay View Post
    That’s what I used on my RTS....I’ve also removed dealer decals from my car this way. Worked for me!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    W D 40 works
    Bossier LoUiSiAna
    +1 hair dryer -gently heat to remove & rubbing alcohol clean up Fingernail or credit card /driver’s license type to lift the corners preferably no blades can gouge/cut the tupperware
    Mar 2021
    Maryland
    +1 on the hair dryer and goo gone. But quite frankly If a dealer presented me my Spyder with a Decal in that location on the front I would say where is my Spyder at because this one is yours seeing as it has your name all over it.
    2020 F3 SE6
    2020 F3 , Black
    Dec 2016
    Georgia
    I used a hair dryer to take one off my car. I told my dealer I didn’t want it, so they gave me a discount for the advertising if I kept it. I accepted the discount then removed it as soon as I got home.
    2022 RT , Hyper Silver
    Jan 2021
    northeast pa.
    very bad that a dealer would do that do your machine, i would have been pissed off, big time
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    found a small bottle of Goo Gone with a small plastic "shoe horned" shaped "scrapper at Walmart. Put on 1 coat of goo and 2 of 4 came off. Put another coat on the last 2 stubborn decals and all came off, didn't damage the paint at all.
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    there are two options for dealer decals. either demand an ongoing advertising stipend from the dealer for advertising for them (and they won't?) OR have the dealer remove the decals. If they damage the finish they will have to repaint the entire area/bike..
    BIG F
    Aug 2019
    Stoughton, WI
    Another vote for using a hair dryer. You can easily melt your plastic with a heat gun. They get HOT.
    2022 RT Sea To Sky
    Mar 2022
    PA
    Thanks for all the help / suggestions. I used a small amount of heat from a hair dryer and they all pulled off quite easily with no sticky residue left behind.
    Linden, CA
    Quote Originally Posted by CloverHillCrawler View Post
    I have done that when buying a new car.... the dealer had drilled holes in the trunk lid and put a metal dealer logo on the back the holes were for 3 screws sticking out the back of the logo and they put a flat washer and a lock nut on it inside the trunk lid. I refused delivery unless they replaced the trunk lid, they were not happy about that. They pulled another car just like it same color and removed the trunk lids and switched them....
    Aug 2020
    Omaha, NE
    Secret to not leaving glue residue, is to pull SLOWLY.
    Former body shop employee. Trust me.
    I may be dreaming. But, I hope to get a Spyder or Ryker, soon.
    Just read through "Do-s-and-Do-Nots-for-new-Spyder-owners" and the following posts. Lots of good/helpful info.
    Lots of other forums could go to school on this.
    Oct 2021
    Wichita, KS
    As you are already done this won't matter. You can just peel them off. Orange oil is the best at removing residue and not harming the paint.
    There's no place like G28 X0 Y0 Z0
