Results 1 to 15 of 15
    Dec 2012
    Murphy, NC
    Default Lost the wire retaining clip fm Brembo Brakes - Do I need it?
    I have lost the little wire clip that attaches to the torx bolt on a Brembo brake caliper. The torx bolt screws into the brake caliper and goes thru each brake pad. It seems to me that the only purpose of the wire clip is to keep the bolt from backing out of the caliper. I cannot find it in the BRP parts fiche or thru Cheap Cycle Parts. 1. Do I really need it? and 2. If so, where can I find one? I checked with BajaRon and he doesn't know where to get one.
    Last edited by Peter Aawen; 03-31-2022 at 05:10 PM. Reason: Removed Prefix - not engine/size related
    2020 F3 Ltd
    Spyderpops Bumpskid
    Feb 2019
    Portland, Oregon
    ACE HARDWARE. It's a stock item, not proprietary.
    Jul 2010
    Las Vegas, NV
    John, remove it, take it to Ace or any industrial hardware store, get a replacement. I’ll search for a pn for you. Joe
    Joe Meyer
    Dec 2012
    Murphy, NC
    Is it really necessary to have the clip??
    2020 F3 Ltd
    Spyderpops Bumpskid
    indpls in
    safety clip yes
    Jan 2019
    Kentucky
    47b Spring/Pin/Clip Kit 219800238 The clip is part of a kit. Item number, description, and part number.
    Dec 2012
    Murphy, NC
    But I don’t want to purchase the whole kit if I can avoid it.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Jan 2019
    Kentucky
    Try searching brembo motorcycle brake caliper pin clip.
    Feb 2019
    Portland, Oregon
    Come on guys, it's not unobtanium, it's a hardware store item. If they don't have the exact item with the bend, an R-pin will suffice.
    Since everyone wants to mail order everything now, I'll go to my ACE Hardware, pay maybe 10 or 12 cents and charge you $1.89 plus $5.95 shipping. What's your address? Sarcasm emoji.
    Dec 2012
    Murphy, NC
    I found the clip! I thought I had lost it but I found it on my garage floor. It had slid under my tool box. Thanks everyone for your help. If I ever need another replacement I will try ACE hardware.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Bossier LoUiSiAna
    Quote Originally Posted by JKMSPYDER View Post
    glad found & not damaged or stabbed in deflating a tire or something
    Jan 2019
    Kentucky
    Glad you found the old one. Ride-on.
    Oct 2011
    Kalamazoo, Mi
    Or in a pinch that's what blue thread locker is for.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Feb 2022
    New Zealand
    Great you found it.
    I was about to suggest a normal split pin.
    Just been looking at the rear pad change.
    Thought that pin was a good idea.
    Harrington, Australia
    You didn’t find my 10mm socket under your toolbox as well, did you JKM?
    Seriously though, glad to hear you found it.
    Pere
    HeliBars Handlebars
    Kenda Kanine rear.
